Results 1 to 4 of 4
- Oct 2009
- 16
January 17th, 2010 12:14 AM #1wile i was driving suddenly parang mamamatay ang engine so pag di mo inapakan ang gas, tuluyang mamamatay ang engine, then to start it dapat naka alalay sa gas pedal at habang naandar nakaapak dapat lagi sa gas. then habang naandar parang sinisinok ang engine. plz help
January 17th, 2010 01:05 PM #2
try to check the spark plug if it is wet with fuel or if too much carbon deposits are present. if it is ok have your carburetor checked.
- Jan 2007
- 137
January 17th, 2010 04:29 PM #3check mo rin fuel filter, fuel pump, fuel pump relay, high tension wire
- Oct 2009
- 16
January 17th, 2010 07:41 PM #4tnx for all the help, pinacheck ko today sa trusted mechanic and they found out na distributor cap needs to be replaced and the spark plug, in other words tune up.... and also kaya namamatay ang engine ay dahil sa P.C. Valce wich is barado na, so oks na ung car and mas tumulin pa, tnx to everyone!!! This site is the best!!!
And you can't opt out of the update.
National ID Law
