Page 1 of 3 123 LastLast
Results 1 to 20 of 53
    Feb 2012
    Mga sir need na ba maoverhaul ito kasi 1 year na d na change oil pero d gaano nagagamit
    Feb 2012
    Yan na po yung langis nya
    Feb 2012
    Btw isuzu c190 yung engine mga sir
    Jul 2011
    what oil does it use and ano filter?
    for a 1 year old engine oil, na nasa engine na bihira pa gamitin, maruming marumi na yan, imo.
    how many kms by the way yung bihirang pagkagamit ng sasakyan sir?
    sa unang tingin, mukang walang coolant na halo kasi itim na itim, supposed to be pag may
    nahalo coolant, brownish ang kulay.
    Feb 2012
    Hd40 ata yun yung sa petron.. nasa 5tkm yung filter niya tig 70php lang pang kargahan tsaka pamalengke lang ang gamit nung xlt
    any other reason why overhaul? change oil and see how it performs. kahit 1yr ang conventional oil and itim na itim with low mileage it. doesnt necessarily mean overhaul agad.
    Feb 2012
    Baka kasi bumara yung mga parang grasa na langis hehe o baklas lng ng oil pan?
    Jul 2013
    Quote Originally Posted by sotel View Post
    Yes. Bakit hindi baklasin mo muna ang oil pan tapos linisin yung kaya malinis doon. then baklas valve cover then linis ang kayang linisin sa valve cover.
    Then pour some cheap oil plus engine flush. Change oil filter (cheap one may be at this point).
    Run the engine for a few kilometer or idle for a some time. Then drain again. Kaya ok lang cheap oil filters kasi drain naman agad.
    Then fill again with oil and change oil filter also. As you use it daily, observe the oil color sa dipstick. You might change oil again sooner since it looks like sludge is heavy.
    [/QUOTE]
    Feb 2009
    Sludge & Heavy Oil Burning
    http://www.auto-rx.com/sludge-oil-burning.shtml
    Jul 2017
    Mga sir gandang hapon po! Sorry po newbie lng po pagdating sa sasakyan. I am driving a mazda 3 2004 model. Tanong lang po if may idea po kayo kung mgkano po mgpa top overhaul and san po kya may maaus na talyer at idea po kung magkano abutin? Recently po kasi nag overheat ung sasakyan ko and kala ko po dala lang ng leak sa water overflow reservoir which napalitan ko na po ngaun ng bago but still unti unti pa rin po nauubos ung tubig sa reservoir. Tapos po knina pag check ko po sa oil dipstick at engine oil cap may sludge po na prang kulay gatas po. Sabi po ng friend ko bka may tama na daw head gasket ko. Sana po matulungan nyo ko. Mejo tight din na po kasi budget ko.
    Ask na rin po sana ako if safe pa po ba idrive ito? Right now po ngsstart na po ako mgipon ng pera dahil ang sabi po sa akin maghanda na daw ako ng budget at mahal daw po mgpa top overhaul... please po tulungan nyo po ako.... salamat po
    Sep 2012
    Quote Originally Posted by rcdgreat View Post
    Kung palit head gasket yan it will go around 7 to 15 k depende kung saan ka magpapagawa kasama na parts.
    Mag canvass ka muna kung magkano head gasket mo and as much as possible yung original.
    Sa shop naman na hahanapin mo. Go ask them if they have a torque wrench. I research mo na rin kung ilang torque ang kailangan para sa unit mo... hindi kasi pwede yan sobrang higpit at lalo na hindi pwede na maluwag
    Sent from my ASUS ZenFone 4 using Tapatalk
    Jul 2017
    Quote Originally Posted by jodski View Post
    Sir jodski salamat po sa help nyo... ask n lng dn po ako if san po mganda mghanap ng murang parts ngn mazda 3. Ang quote po kc sa akin ng pagawa ng top overhaul eh mghanda daw ako ng 30-50k. Tama po b un?
    Do you have check engine light on? What is the odometer reading? Why not oil change kahit pinaka mura just to get clean oil?
    imho, i think the worst thing can happen is for you to change the seals... baka kasi tumigas na.
    Apr 2015
    Hi sir, ask ko lng po why mnsan nag oon ng matagal un check engine light? Honda city esi 98 Mnsan nmn po nkaoff.. Please help po thanks.
    Mar 2015
    Quote Originally Posted by gorgeoustin View Post
    Have your car checked with a consult maybe theres a malfunctioning sensor
    Mar 2015
    This what we call sludge. Old oil becomes like this inside our engines. Best is to clean everything first. Flush your engine make sure everything is clean and fill it with new oil and start it.use the car and observe it before going for an overhaul
    Mar 2015
    Please change your engine oil at 5k kms or 6months whichever comes first. Irregardless of what kind of oil you use.
    Quote Originally Posted by SkyFlakes88 View Post
    this is what the manual recommends..?
    me, i change oil after every 5K.. even if it takes me a year..
    Feb 2009
    Irregardless???
Need na ma overhaul yung engine?
