pinacompression test ko kahapon sa petron commwealth ang aking toyota 96 gli the result was 150 120 150 155.... is this result ok or should i need to have it fix?...moreover i was observing the procedure done by the mechanic.. ive notice that he merely place the compression gauge on each spark plug hole and have me crank the engine while he was getting the readings....per internet and manual however it would appear that the following procedures should also be done....1)throttle must be fully open and 2) the ignition coil should be grounded... ok lang ba yung ginawa nung mechanic or should i have to repeat the compression test...any recommended shops? ty
ok pa naman takbo ng kotse at la pa naman akong na papansin na usok.. medyo nag babawas lang ng unting oil...kailangan na bang i overhaul,,o dapat i test pa further,,ty
