Results 1 to 4 of 4
    Jul 2013
    good morning mga sir..
    Mazda 323 familia 1996 glxi ang o2 ko..
    inquiry lang about clutch issues.. anybody here na nakaranas na pag tumatakbo kayo and you shift gears na parang nahihirapan yung o2 mag accelerate? there are times na naka aircon man o hindi mararamdaman mo yung normal acceleration mo. pero sa akin kc may times na parang nagsslide cya..
    nakapagpalit na po ako ng clutch master hanggang dun sa pinaka ibaba.. ilang beses na namin pinatingin yung issue na un pero hindi namin nakikita.. may nakapagsabi naman skin bka daw clutch relining dw.. gusto ko lang sana manghingi ng mga opinions nyo..
    thank you sa mga input nyo po and more power..
    Jul 2013
    Quote Originally Posted by IllidanCarlisle View Post
    mga sir parang mali yung thread na nalagyan ko.. sorry..
    Feb 2009
    what is the mileage of the car? who had been driving it, was it a novice driver or a seasoned one. where was it usually driven? has there been a leak of oil at the rear of the engine? if the clutch was worn out, i would recommend replacement of the clutch disc, pressure plate, release bearing, pilot bearing, rear main oil seal as a set. this sounds like a lot of parts replaced but the difference in the cost of just having the clutch disc relined and everything else as is is not cost effective specially the labor for this operation is not that cheap. if maybe it was a jeepney, maybe yes since the accessibilty of the clutch and associated parts replacement is easy. take care of the MAW (might as well parts), ti will save you money and it will save you from the inconvenience and waste of time
    Jul 2013
    sorry sir kulang specs ko =)
    i got it second hand sir.. wala naman pong leaks or tumutulo sa rear part.. mileage is almost 190 na po pero i know na naadjust na yung mileage nya.. daily driven ko lang cya since then.. got it 2006 po..
    mga how much kya abutin nung palit if ever sir?
    thank you sa input
Clutch Problems?
