Results 1 to 10 of 10
    Oct 2008
    whats the best way to clean your airfilter? thanks po
    May 2007
    If it is reusable like those K&N or AEM filter's you'll need a Recharger Filter Care Service Kit. If your filter are just the regular one, throw that away and get a new one.
    Quote Originally Posted by v6dreamer View Post
    To add
    pwede rin pa spray mo ng malakas na hangin on the clean side of the filter if it is an oem filter.
    tipid konti but masisira ng konti yung filter.
    uso naman yan dito
    First off, check what your manual says. If it says change, then change, if it says you can still clean it and use for x amount of kilometers, you can follow the instructions and the filter will still work.
    In the event that you can clean the filter, you have to use some pressurized air from a compressor and clean it from the inside, out. Do not use the air to blow from outside, in as this will push the dirt further into the filter and damage the element which gives your engine a greater chance of breathing in bad air.
    Hope this helps.
    Jan 2008
    i use vacuum cleaner to suck dirt from the outside then flush with air from the inside..just be careful not to damage filter element(fiber strands from the inside) or it will add up to dirt going to internals like maf sensor
    Oct 2008
    ah thanks po yun filter ko po simota na cone type. so use air lang po to clean? how about liquid solutions? maka damage po b yun?
cleaning air filter
