Results 1 to 6 of 6
- Oct 2004
- 3
October 31st, 2004 11:25 AM #1Hi! This is my first post.. Napansin ko kasi na pag matagal na na running yung car, tumataas ang idling nya, and nawawala ang lamig ng aircon, but when I turn off the aircon, balik sya sa normal. What do I do? First I thought madumi na aircon, so pinalinis ko, then ganun pa din. Tapos, pinapalitan ko ng spark plugs and nagpa tune up, still the same thing. This is really annoying na. Help!
BTW, stock po sya, '93 model. If you guys have any tips for the additional boost in accelerating power na rin, please do post 'em here,
Thanks in advance!
October 31st, 2004 12:38 PM #2
How much different is it? The idle controller usually raises the idle when you turn on the AC, but if it's much more than 1000rpm, that's not normal.
- Oct 2004
- 21
October 31st, 2004 12:42 PM #3Originally posted by Hans
Thanks in advance!
Maraming puede iconsider pagdating sa problem mo. You have to check a couple of things.
First, tignan mo ung magnetic clutch ng A/C compressor kung gumagana(that is when the symptoms occur-kung tumataas na uli ang idling). Second, check your compressors relay kung umiinit.
Your problem i think is A/C related. Nawawala ang load ng compressor kaya tumataas ang idling ng engine. For any questions regarding automotive troubleshooting and repair, contact Ramil at Ramtec Motortech 6558603 or txt 09183000108.
- Oct 2004
- 3
October 31st, 2004 12:55 PM #4Niky, la po ako guage para sa rpm, pero sa tantiya ko 1,000 pataas nga. parang nakaapak ako ng 1/4 or 1/5 sa gas pedal, ganun kataas ang idling..
Aquaman, pinatingin ko na sa pagawaan ng aircon, pero la silang makitang problema. Ang nakakaasar kasi, pag bagong start, di nangyayari yun, so kala ko ok na pagkagawa, pero once naitakbo ko na ng mga 30 minutes up, saka umaangat ang idling. San po yang Ramtec? Pasig or taytay area? 655 is still in pasig right?
Thank you po sa mga reply!!
- Oct 2004
- 21
October 31st, 2004 01:02 PM #5Originally posted by Hans
Tawagan mo nalang ako sir. Tlungan kita dyan. San ba location mo?
- Oct 2004
- 3
October 31st, 2004 01:26 PM #6Thank you po sa mga nag post! Punta ako later kila Ramil after work. Papacheck ko na.. Thanks again!!
Xiaomi E-Car
