Results 1 to 10 of 10
- Jan 2007
- 409
January 10th, 2013 08:28 AM #1I believe there are 4 major sellers of these products
DTS/DTP
RaceChip
Uni Chip
DPChip
Any current feedback on this kind of modifications?
I am not really into high performance but to improve efficiency of the engine. Better power better consumption
Can someone also give the current seller and pricing of the chips.
Thanks
January 10th, 2013 01:16 PM #2
Unichip.
Universal, can either save money by going basic (30k) or go for painless install by going plug-n-play.
Options for multiple maps (up to four separate maps), for wiring in alcohol injection triggers, launch control, etcetera.
Specifically tuned for your vehicle and mods. No over the internet guesswork or retuning. Gains tested and proven via dyno.
What else do you really need?
January 16th, 2013 10:45 AM #3
January 16th, 2013 11:53 AM #4
]i installed dpchip from berrima diesel for my carnival. torque now is up. i can feel the difference. my carnival can now change with ease to higher gear below 2000rpm on automatic mode. dati above 2000rpm before gear shift from 1st to 2nd to 3rd gear. ngayon at 1700-1800rpm nag upshift na siya. also the hp is up. above 3500rpm kaya pa niya mag accelerate. dati above 3500rpm wala na. fuel consumption observe ko pa though tingin ko minimal lang siguro kasi short distance travel lang ako. sarap na mag overtake sa highway.
January 17th, 2013 01:13 AM #7
- Jan 2007
- 409
January 17th, 2013 07:20 AM #8
January 17th, 2013 10:33 AM #9
January 19th, 2013 10:53 PM #10
sir niky, OT. what do you think of sprint booster? Knew that there is no added power but just faster throttle response, but noticed that by MS smokes during hard acceleration when I have this switched ON, none when it is OFF. Berrima also told me that sprint booster tends to make the mixture lean that is why it is belching black smoke...thanks.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
