Results 11 to 18 of 18
- May 2007
- 101
February 28th, 2010 08:14 AM #11nalilito ako dun sa pickup ko(nissan eagle), pag kakaandar lang ng makina then after mga 5-10 mins nakapatay, yung oil level nya sa dipstick is mga 1/2 lang.
pag overnight naman nakapatay then check sa umaga e lagpas sa full.
nag overfill kaya ako?
February 28th, 2010 01:43 PM #12
oil travels inside the engine when in use, so it does not stay in the oil pan/catch(forget the exact term) underneath the engine. and of course, if engine is off, the oil drains back to the oil pan, that is where the dipstick reads the level of the oil.
if lumagpas sa full level ang reading, maybe you have overfill it. its not that harmfull but on your next change oil, better be sure to fill it just right.
lutang pa koLast edited by aejhayl17; February 28th, 2010 at 01:46 PM.
February 28th, 2010 04:20 PM #13
That's right! Kaya mas magandang mag check ng oil level pag umaga, before starting your engine.
IMHO, overfilling your engine with oil may not cause harm to it but will affect its performance . . . Sa experience kasi namin ay medyo hirap humatak pag "lunod" yung makina sa langis.
Last edited by jjmd3_787; February 28th, 2010 at 04:27 PM. Reason: tao lang po . . .
- Mar 2004
- 652
March 2nd, 2010 06:24 PM #14Mga sirs, try running on a knee deep water. tignan kung gaano kahirap. this is comparable to an engine overfilled with lube oil.
- Mar 2004
- 652
- Mar 2004
- 652
March 2nd, 2010 06:32 PM #16Mga sirs, try running on a knee deep water. tignan kung gaano kahirap. this is comparable to an engine overfilled with lube oil.
March 2nd, 2010 10:30 PM #17
- Mar 2010
- 6
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
