Results 1 to 6 of 6
- Sep 2013
- 23
April 24th, 2019 05:28 PM #1Hi mga sir's
Ask lang po ng help.
I have honda 2005 matic dimensional. Recently bigla bigla nalang lumalabas ung check engine ko.. pinabasa ko sa obd reader dati and ang code is 02 sensor fault nga. So ginawa ko nag order ako sa casa ng bagong oxygen sensor na napakamahal pla...wew. after na mariciv ko yun, pina install ko and delete codes na error.. pero after mga ilang days lumalabas pa din yung same error. Me idea kaya kayo mga boss?
Ito exact error code:
01-1 Heated 02 Sensor Voltage High
-Sensor 2
Thanks in advance
Sent from my CPH1823 using Tapatalk
April 24th, 2019 05:36 PM #2
- Sep 2013
- 23
April 24th, 2019 05:39 PM #3Sir sinabi saken ng mechanic na oxygen sensor lang bilhin..and iisa lang din nman yung sensor nung car ko.. so ayun po yung pinalitan ko
April 24th, 2019 06:19 PM #4
Check elsewhere.
An O2 sensor high-volt (assuming that the sensor is good) means that it is sensing a rich fuel mixture. Normally, when the computer receives a high-volt reading, it makes the engine run lean. If it still receives a high-volt, then there's likely a source of unchecked raw fuel coming in somewhere.
You may want to check for leaking fuel injectors or bad sparkplugs and/or ignition coil/coil packs next.Last edited by oj88; April 24th, 2019 at 06:24 PM.
- Sep 2013
- 23
April 25th, 2019 07:17 AM #5
April 25th, 2019 09:00 AM #6
Also check the wiring harness of the oxygen sensor.
agree ako syo. battery dying will be the next owner's problem. kaso the only reason I'm buying...
All New Toyota Corolla Cross
