if the scan gives you the ISC problem then that's the problem. try to clean the ISC valve. there are videos in youtube on how to do it. usually brake cleaner lang ang gamit na panlinis. and while you are already on it, remove and clean the throttle as well as other sensors attached to the throttle with the brake cleaner.
