Results 1 to 13 of 13
    ask ko lang bakit ung advie nmin ay kumakalog kapag ino-off ung engine long run or short run, basta pag papatayin kumakalog sya. sbi ng iba ay kaya ganon gawa ng nk advnaced daaw ung timing ng engine. tnx sa mga magrereply.
    it is an effect of an "overly advanced" timing. if you're timing is stock (as per manufacturer specifications), it could be a faulty ignition or dirty combustion chamber (carbon deposits). as for the carbon deposits, it may sound a bit silly, but hataw driving could do the trick. change oil frequently, as well as other things plugs, filters.
    Sep 2006
    Normal yung kumalog ang diesel engine sa very low idle, lalo na sa pag shut-down. Mataas kasi ang compression pressures ng mga diesel engines.
    Meron additional device ang new diesel models para mabawasan ang pag kalog.
    So don't worry.
    May 2007
    Do you mean just a little "shimmy & squeak"? That's normal on almost all diesels. The thing is, the combustion events in a diesel are so abrupt, ganoon din sa mga gas engine, that when you shut it down, the engine stops like RIGHT NOW, and the accessory belt keeps going momentarily, causing the squeak. The abrupt shut-down also causes a little shake when you shut the engine off. It's more pronounced in the Cummins than the PStroke or Dmax, but they all do it to some extent.
    Quote Originally Posted by spyghost View Post
    tnx spyghost
    thanks dieseldude, I think this week pupunta father ko sa central diesel.
    Thanks a lot sir.
    Quote Originally Posted by v6dreamer View Post
    THanks a lot sir
    Jun 2005
    How old is your advie? Baka worn out na ang engine support.
    :coffee: [SIZE="1"]4123[/SIZE]
    agree. suggest to check out your engine support and transmission suppport, pag malambot na yan or may crack or nakasayad na, aalog talaga engine mo..
    [quote=j_avonni;1187320]How old is your advie? Baka worn out na ang engine support.
    :coffee:
    sir 2003 model 4d56 Diesel nga pala, 68K Mileage. thanks sa advice sir. I learn a lot of things here in tsikot.
    Quote Originally Posted by pr462 View Post
    pr462 sir thanks for the info. we will chek it.
    Quote Originally Posted by arnielbenz View Post
    nangyare sakin din to, i did a research way back. engine support daw e sira pag may added vibration na sa engine and maybe yes pag pinapatay mas may nginig. sakin naman minsan lang ngyre yung nginig, ang naging solution for me is hinahataw ko minsan takbo.actually nangyari nnmn kanina umaga na nanginig nung nagpatay ako makina nung sa gas station, gnwa ko binirit ko ng mga 120km/hr sa highway. pagdating sa ofc ok na ulet, wala ng nginig pag patay. baka lang pareho tayo ng issue. ride is a hilander 2.5 slx
Kumakalog ang engine kapag pinapatay
