bakit di mo nalang tanggalin ang carb mo at dalhin mo sa kamuning? iwas sakit ng ulo. pag butterfly ang problema, di kaya sa repair kit yan. may i suggest rommels shop sa kamuning. kaya nila ibalik sa OEM setting yan. ikaw na rin magkabit pagbalik mo. isang oras lang yan, tapos na. mahirap magkumpuni ng carb kung di mo kabisado, very complicated sa dami ng parts sa loob.
Salamat sir. Yun talaga gusto ko gawin. Try ko baklasin. Lakas loob nalang ako, baka kasi may mahulog o maiwan o may mali. Kaya naman yata i-set ang air/fuel ratio kahit hindi nakakabit?
sir try to watch this video.
Aisan Carb Rebuild [ame=http://www.youtube.com/watch?v=6mJHc3YjwPQ]Rebuilding an Aisan Carburator Part 1 by Pin Head.mp4 - YouTube[/ame]
medyo hawig carb ko dito kaya naglakas loob akong i-troubleshoot mag isa
Thanks sa video sir. Pero parang mas hawig to sa carb ng 16v corolla ko. Yung sa L300 mukhang ibang iba. Di ko alam kung aisan din o hindi. Baka pag baklas ko makita yung brand ng carb. Thanks again.
Mga sirs. May idle na yung van. Binomba ko ng binomba gas pedal sabay spray ng carb cleaner. Umusok ng itim pero nawala agad. Tapos may idle na 800rpm. Pero kelangan pa rin ipa check. Will bring it to kamuning. Thanks to all.
Peace out!
Hello sir
I'm new here sa tsikot.. I seek for help kasi di maayos sa rapide yung carb ko.. Honda eg 94 model na gamit ko po.. Badly needed ang help.
Prob nya lagi nag choke. Khit naka neutral continues yung flow ng gas sa carb. Khit.di tinatapakan yung gas. Napa ovehaul ko sha sa rapide. Pero still no good(
Tnx in advance guys.. Noob pa kasi when it comes to cars
Giod day, God bless!
there are many "dependes" sa question mo.
on buying: is there a new unit available? are you willing and able to spend big money for it?
on repair: does the person know how to repair it? are there parts available?
of course, if i had the money, i'd want to buy a new carb... it's the easiest solution!
offhand, i think your old carb can be fixed. all you have to do is find someone who knows how.. not every mechanic today knows his way around a carb.. i am told the carb people are along kamining...
based on your description, i'd say your carb needs to have its float level adjusted. provided the valve is still in there. carburators have lots of very small parts that can just drop off and get lost if you turn over the unit..
Sir dr. D
Sir thanks sa advice.. I will go to kamuning asap. Btw sir my recommendation po ba kayo sa kamuning that specializes on honda carbs?
Thanks soo much sir
^^^ sir pagda rapide ka nagpagawa magiging brand new ang sasakyan mo.
Mapipilitan ka na lang kasi bumili ng brand new kesa ipagawa ng ipagawa sa kanila.
Masyading mahaba horror story ng rapide dito sa taikot sir. Iwas iwas lang sir at pagnakita nila na kaya ka nila manipulahin madadale ka lalo.
Posted via Tsikot Mobile App
