Results 1 to 16 of 16
Rpm
    Mar 2007
    Sir, what is the ideal rpm level w/o aircon? Is below 500 fine, or it should be between 500 to 700? TY
    Jan 2010
    Quote Originally Posted by CarPainter View Post
    sir, what is your car? sa montero diesel engine manual, it is 650 ±50, or 600 - 700 rpm, aircon is switched OFF....hth...
    Mar 2007
    Quote Originally Posted by rmsoriano View Post
    92 honda hatchback sir. TY
    Jul 2006
    600 to 700 rpm should be fine. Do not go below 500, your alternator may not have enough rpm's to charge properly, and your water pump may not rotate fast enough to ensure adequate coolant circulation.
    May 2009
    lubricating oil pressure ay apektado rin. plus you are lugging the engine too even at that low idle speed.
    Aug 2008
    sir, normal lng ba kung ung rpm ay bumababa pag naka AC? from 1000 rpm to 600 rpm, corolla 95 MT, 12 valve, carb.
Rpm
