Results 1 to 8 of 8
    Jul 2010
    mga sir,
    bakit ganun po problema ng kotse ko
    tumutulo na engine oil pag umaandar ang makina, wala naman pag nakapatay.
    simula po nangyari yan noong nagpachange oil ako, dati po wala naman po tumutulo.
    naka isang litro na po ako nang lagay para mamaintain ko lang ang oil level ng makina
    corolla toyota 1997 xl po kotse ko
    may kinalaman po ba sa langis na nilagay namin po noon, shell helix 20w 50 po nilagay noon,
    salamat po.
    Feb 2009
    Quote Originally Posted by botellog View Post
    mga sir,
    salamat po.
    the last thing done was oil change. your leak is a pressure leak and the only possible source as per your description would be a loose oil filter
    Aug 2003
    did you check first kung saan yung source ng oil leak?
    agree with jick, kung oil change yung last job baka loose lang yung oil filter.
    dalhin mo ulit sa pinag-change oil mo and complain about the leak.
    silipin nyo kung yun nga yung problem.
    Feb 2003
    If those were the circumstances chances are 90% na yung suggested sayo ng mga previous posters is correct..check the tightness of the engine oil filter. It is also very important to check for the conditions of the O-ring kahit pa yan eh bago and straight from the box filter. Always inspect it and put a dab of oil in it para magmate sya ng maayos kapag ikinabit sa engine. Dapat apply correct torque lang din sa filter not too tight or too loose.
    Jul 2003
    bring the car to a service station and lift it up to look for the cause or origin of the leak.
    Jul 2010
    pumunta po ako sa shell service station kahapon, na pinag change oil lan ko last month.
    okey naman po yung oil filter at yung turnilyo ng oil pan drain. wala pong tagas.
    ang may tagas po sa gilid ng oil pan along the sealant.
    suspetsa ko kasi, pwenersa yung pag tanggal noon ng turnilyo ng oil pan drain at di kaya namis align yung sealant ba yun between the oil pan and the engine.
    kaya tumutulo po ba habang umaandar dahil sa pressure na galing sa loob ng makina
    salamat po guys sa mga tumulong..
    Kailangan patangal mo ulit oil pan linisin mabuti ang paglalagyan ng sealant. High temperature sealant na gamitin mo.
    Jul 2010
    Quote Originally Posted by speed unlimited View Post
    sinilip ko nga din, silicone kulay black ang nakalagay doon sa oil pan.
    okey lang po ba high temperature sealant na gagamitin, ano po brand na maganda.?
    hirap kasing pangunahan yung mekaniko baka magalit pa.
    salamat po sir
