Quote Originally Posted by 1997 View Post
Dalhin mo sa Kamuning. M2m pangalan ng Carb specialist.. Dun ako nag papagawa ng Carb ko... although nissan sa aken...
Thanks po, ..
Quote Originally Posted by dobemarbia View Post
Hi joyluck, I had the same 12R engine in my toyota silver edition years ago. The carb cleaner you used might have "cleaned" the carburetor but i still suggest that you have an experienced mechanic overhaul your carburetor. Purchase a repair kit and have the mechanic replace all the jets.
As for the the engine idle going down to 200 RPM when the aircon is turned on, I think you would need to adjust your idle speed to around 900 to 950 RPM. This engine is not equipped with a vacuum actuator that increases idle speed when the aircon is turned on.
It is quite normal that idling drops when headlights are turned on due to the extra load in the alternator.
I am doing your advise, i already bought a carb repair kit then sa monday ay carb overhaul na.. One more thing na pinagawa ko is pinapalitan ko un gasket from intake manifold to muffler pipes kasi hindi daw nilagyan ng nag gen overhaul at malakas daw ang singaw doon, about the aircon issue, wala daw vaccuum hose para sa ac un carb na nakakabit sa engine ko (pang 5k ang carb) Is there any other way i can use my aircon without having to change my carb? thanks!
