When you say stall, do you mean its completely dead? If so, check fuel filter, external fuel pump, ignition coil or tension wires. Since engine is carb, checking fuel supply is easier than injected engines.
For fuel filter issue; filter should at least have half contained with fuel. Try using a 60.00 plastic filter para 'kita agad kung may gas sa filter. Once you have change out the filter, try cranking the engine to check if at least umaabot ba sa filter gasoline mo. If the fuel is there, check fuel pump. Try using a pressure a gauge. PSI should be about 7PSI from pump to carb. Assuming your carb is okey, try checking the ignition coil. Try borrowing a different coil and see if this resolves the issue.
Now, the worst thing that could happen assuming carb is working just fine, fuel delivery is great, coil and tension wires are working just fine as well, check cylinder functions, 1,2,3 and 4. On this part better consult a good mechanic, or better yet have it check by a mek right away.
