Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
    #21
    sirs!
    meron problem yung mitsubishi lancer ko, GLS 2002. Lately lumabas yung check engine habang nasa edsa ako, tinabi ko agad para sa service bay then eventually namatay. Inistart ko ulit, umandar naman, then lumabas yung check engine, sakto nasa office na ako.
    Now, kinausap ko yung mekaniko ko, dinala ko sa shop nya. Nung una hindi pa lumalabas yung sakit, normal na start.
    Halos Tune Up naarin yung ginawa dahil pinalita na yung sparkplug, oil filter, oil cap, nilinis naman lahat. eventually lumabas yung check engine then namatay. Eto na yung sakit, mag sstart siya, after 2-3 secs, namamatay buong makina. Pinalitan nila ignition coil, same din, bumalik parin sakit, tinignan naman yung crank system, ok naman pero eventually andun parin yung sakit.
    Inayos yung air filter, then hindi lumabas. Pag uwi ko, lumabas ulit yung check engine, may phobia na ako, kasi anytime pwede ako tumirik sa daan, anywhere.
    As of now, kahit may inayos na, lumalabas parin yung check engine, hindi ko ma biyahe ng malayo, takot tumirik.
    mag iniwanan ko siya, after 1 or 2 hrs, aandar naman siya siguro 1 or 2 hrs, deads na ulit .
    ano kaya possible na sira nito sir? i pay 4k and ended up nothing. Probably changed oil kaya eto? oil pump? gas? ano kaya?
    Jan 2009
    #22
    Quote Originally Posted by migz1968 View Post
    sirs!
    You need to have it scanned to read the Diagnostic Trouble Code (DTC). The code will tell you what triggered the Check Engine Light (CEL) so you'll know what needs to be repaired. It may not pinpoint the exact failure but at the least, it will help narrow down the issue to a few components.
    Jan 2009
    #23
    Double.....
    #24
    Thanks sir! btw, dati nag pa scan ako (servo), dun sa scanner niya, wala yung model ng lancer 2002. Hindi rin nya na scan.
    If possible sir, meron kaya shop na marread nya yung 2002 Lancer ko?
    #25
    Jan 2009
    #26
    Try another shop.. Servitek maybe.
    Or try your luck with Google. There are DIY ways to get a 2 to 3 digit code that will correspond to a Pxxxx OBD2 code. The following links are reference only. FOLLOW THEIR ADVICE AT YOUR OWN RISK. I suggest that at the least, you look up the exact model of your car.
    https://youtu.be/8_kAkT3onw8
    HOW TO: Read Diagnostic Trouble Codes - Club3G Forum : Mitsubishi Eclipse 3G Forums
Car Problem
