Results 1 to 6 of 6
- Jul 2005
- 122
August 30th, 2011 10:12 PM #1fellow tsikoteers, I recently had a change oil and and made an error. I requested the guy handling my vehicle na dagdagan pa yung oil bec the dip stick's marker hasn't reached max. He poured more oil til the dip stick reached the desired level. After several days, I checked the dip stick. Its about 1/2 inch above the max level. Too much oil. Will this cause problems in my engine and other parts?
If its gonna damage the engine, then I'll have to reduce the oil. Pano ko babawasan? Thanks in advance.
Vehicle - Honda civic 96 vti
August 30th, 2011 11:52 PM #2
yes, it will cause some in your engine. first is oil frothing. next is excess load in your engine's internal parts which is stressful on your engine.
August 31st, 2011 08:35 AM #3
the effects are:1. as mentioned by sirboss, causes frothing- foam does not lubricate the bearings properly,
2. it causes engine vibrations at mid to higher speeds, 3. it causes burning oil and might lead to clogged exhaust system, 4. the spark plugs will accumulate oil build up, 5. it makes exhaust gases bluish white and 6. you lose engine power output
- Jul 2005
- 122
August 31st, 2011 10:05 AM #4Thanks for the replies mga bros. It seems di talaga pwede pabayaan na ganito kataas ang oil level. I'll be going to a near gas station to have the vehicle lifted and remove the drain bolt.
August 31st, 2011 01:23 PM #5
leaks at gasketed joints and seals aside from overheating due to frothing of the oil. once the oil froths, it loses its lubricating properties.
only way is to drain the excess via the drain plug.
- Jul 2005
- 122
August 31st, 2011 09:31 PM #6Thanks everyone. Binawasan ko na via drain plug. Finally, peace of mind.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
