Last saturday po I had may valve seals replaced. Kase every morning pagstart sobra mausok, na nawawala naman pag mainit na makina. Nang mapalitan yung seals ok naman, nawala na yung mausok na start-up. What is noticeable though is the decrease in engine power. Di naman palyado yung makina pero noticeable mas mahina ang acceleration compared nung bago sya palitan ng valve seals. Tagal mag reach 80 kph even at 5th gear. Could it be improper valve clearance? Di na kase sinukat nung mekaniko yung tappet clearance nung ibalik yung valves, inalog alog nya lang bawat isa at sabi ok na raw yun, basta wala naman daw tukod. If di naman valve clearance, ano po kaya problema?
Need your opinions tsikoteers!
thanks po in advance
What could have possible been messed up in replacing valve seals so i can have it checked po?
