Results 1 to 10 of 16
- Apr 2009
- 429
November 30th, 2014 09:53 PM #1good day, guys. The Glow plug tip of my hilux LN106 was broken and stuck in the combustion chamber of the cylinder head. I don't like the idea of removing the cylinder head just for that little part to be removed as it involves disturbing too many parts. I checked in the internet and found the "glow plug removal tool" but unfortunately no one is selling in sulit (OLX). Any suggestions, guys?
TIA
November 30th, 2014 10:30 PM #3
December 1st, 2014 09:52 AM #4
if the glow plug remnant fell in the combustion chamber and is of ferrous type metal, try using a telescoping magnet pick up tool through the injector opening.
- Apr 2009
- 429
December 5th, 2014 05:48 PM #5the problem is that the broken tip (which is more than 1 inch) is still stuck in the glow plug hole. It does not even budge. The other 3 glow plugs are also seized up. There seems to be no choice but to dismantle the cylinder head....
December 5th, 2014 06:13 PM #6
Screw extractor.
See here: Screw extractor - Wikipedia, the free encyclopedia
Most hardware stores sell a set.
December 5th, 2014 06:56 PM #7
Unscrew the main body of the glow plug as much as you can and run the engine but prepare a piece of 1/2 plywood the catch the tip when it gets ejected by the compression. Be extra cautious, the tip can projectile violently
- Apr 2009
- 429
- Apr 2009
- 429
December 5th, 2014 07:11 PM #9
December 5th, 2014 07:16 PM #10
Try placing the engine in rocking position (all four Pistons level and halfway) and either drill the tip or push it down using a pin punch slightly smaller in diameter than the tip. Use light taps until it gets dislodged and falls into the combustion chamber. Modify a vacuum cleaner flexible tip to go into the injector hole
high idle RPM at engine start
