Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Jul 2006
    ano po ang benefits kapag bago ang fuel filter? efi na po oto ko
    Sigurado di starved ang engine, smoother and quicker response bukod sa titipid konti.
    May 2007
    It makes your car smile and a very good owner.
    Jun 2006
    more SMILES per GALLON..lolz
    Apr 2008
    better miles per liter/gallon at sasabihin sa iyo ng makina mo...ay salamat pinalitan mo din ang fuel filter ko!:hysterical:
    OT: alam niyo ba kung saan nakalagay ang fule filter ng honda EK, 4 yrs na kasi nung nabili ko ng 2nd hand.kailangan din bang isama sa PM ito? thanks.
    Oct 2007
    Quote Originally Posted by ej_saiyajin4 View Post
    bro, benefits kapag bago ang fuel filter ay syempre mas maganda ang flow ng fuel at mas effective sya mag filter ng moisture or water into your fuel line and large particles objects...ito ito ang mga kalaban ng ating mga engine kaya nasisira agad or premature wear out........
    May 2007
    Quote Originally Posted by n5110 View Post
    Sundan mo yong fuel line para ma trace mo kung saan ang fuel filter, usually nakakapit sa firewall yan.
    Nov 2003
    it's part of routine maintenance every 20-40k kms.
    its located sa likod ng air filter, kabit sa firewall... round shape na medyo 3-5 inch tall.
    would you recommend those replacement fuel filters found in ace hardware or handyman? i think the brand is sasaki
    Jan 2008
    kapanatagan ng loob.
    Sa mga old cars pwede generic fuel filters pero sa mga bago kelangan either Original or OEM , or if replacement it must be specified for your car.
    Aug 2007
    Quote Originally Posted by archie123456789 View Post
    sa gilid ng battery right side, madali lang makita yan kasi hindi nagtatago hindi katulad ng oil filter. ako kapapalit ko lang ng fuel filter ko mas gumanda hatak.
    di ka kabado na baka may mangyari na di maganda sa engine due to dumi sa fuel and some sediments , moisture etc ..
    There's no BENEFIT!
    Your car will just run AS IT SHOULD.
    Jul 2006
    kahit po sa fc?
    As I've said, you're just putting a filter that's SUPPOSED to be clean in the first place. You're asking about BENEFITS... so unless you always drive without a filter or only drive with a clogged filter, then there's no BENEFIT involved.
    Bro I think you check your filter first kung kailangan na echange..Filters should always be change kung marami nang dirt nakastock dyan...Like our air and oil filter, kailangan natin maintain yan to improve yung engine life mo..
    Changed the fuel filter on my VTi recently (April). So far the same lang naman ang consumption.
    I guess I just have a better, cleaner feeling knowing that the old dirt in the fuel system is out.
    Jul 2006
    Peace of mind.
