Results 1 to 10 of 21
- 135
October 29th, 2005 01:31 AM #1kakachange oil ko lang, about 1500 km palang tinakbo ng pajero ko. parang maitim na agad yung langis.
i used pertua na semi synth motor oil, is this ok?normal ba maitim agad langis?
also will be going to bauio ano pa kaialnagn check sa kotse besides water and air?
October 29th, 2005 01:52 AM #2
that is normal.
kahit mga less than 5kms lang takbuhin mo after the oil change, maitim na agad yan. the reason is that hindi naman totally (100%) natatanggal ang engine oil mo. may natitira pa. so, nahahalo to sa bagong lagay na oil. then may mga carbon deposits rin sa internals ng engine mo, which the new oil would be dislodgeing and thus making it black.
check belts, hoses, wiper, washer, spare tire, all the fluids, tools, lights.
October 29th, 2005 09:30 AM #3
yup i agree with tebs. Napansin ko yan sa mga diesel engines, mas mabilis umitim ang engine oil as compared to gasoline engines.
October 29th, 2005 12:21 PM #4
Normal yan wd Diesel engine. Kahit pag 1st engine start palang after your change oil balck agad yan. Use fully synthetic oil yan di agad black ang oil engine mo or mag engine flash ka using new ordinary oil kahit 4lt lang idle your engine 2 to 3 min. hugasan mo yong oil filter mo. then remove it use Helix Ultra.
Tsikot Member Rank 2
- 441
- 135
October 29th, 2005 02:14 PM #7
Dude,
Tip lang. When you'll have an oil change especially sa mga casa or garages na dehins mo kita ung ride mo pag nag change oil is that make a marking sa luma mong oil filter before servicing then re-check it when its done. One time kasi, i had my ride to have its oil changed only to notice that they use the same old filter and just gave me another old filter. :D
October 29th, 2005 07:52 PM #8
Tama po ito. Ito rin kasi ang suggestion sakin ng bayaw ko. Some casas, dimo kita ang pag change oil, umo-order sila ng oil filter, oil, etc. so naka charge sayo yun, nasa receipt. Then kalabas-labasan, di nila nilalagay yung bago, yung luma parin ang ibinabalik, then binebenta nila sa labas yung bago.
October 29th, 2005 08:14 PM #9Some casas, dimo kita ang pag change oil, umo-order sila ng oil filter, oil, etc. so naka charge sayo yun, nasa receipt. Then kalabas-labasan, di nila nilalagay yung bago, yung luma parin ang ibinabalik, then binebenta nila sa labas yung bago.
- 135
November 2nd, 2005 01:26 PM #10thanks!
just got back from baguio..
gaano karami pala ang oil kailangan ng gen 2 pajero?
yung nag pa chage oil kasi ako 1 gallon lang binbibgay ko?
bago ako umalis nag dagdag ako 2 liters oil.
tapos before ako bumalik napadagdag na naman ako 1 liter?
gaano pala karami kailangan oil ng gen 2 pajero?
Life Lessons From A Monk & His Tuned Mini Cooper S - Speedhunters Sent from my SM-S901E using...
Monk-owned R53
