Results 1 to 20 of 20
    Folks, need help.
    Engine is Multicab 660cc 3cyl. Ayaw matanggal yung gitnang spark plug. Yung 2 madali lang natanggal, pero yung isa talagang ayaw. Pag pinihit, iikot ng mga 1ikot tapos matigas na. Hindi ko pinilit at baka lalong lumaki damage.
    Ano ba puedeng gawin muna for the meantime? Puede ba ibabad sa WD40 yung spark plug well?
    Thanks in advance.
    Have you tried using a long nose pliers? Baka loose thread na ang spark plug kasi. IMO do not use WD40 or any fluid to remove the stuck spark plug.
    Malalim ang lagayan ng spark plugs. Kung long nose, dulo lang abot, hindi rin mapipihit. Kung hindi puede WD40, ano pa puede gawin para matanggal other than removing the cylinder head and bringing it to the machine shop
    Thanks.
    crocodile vise grip pwede bro. Merong maliit nito.
    Quote Originally Posted by mazingerZ View Post
    Thanks Bro, kaso malalim yung spark plug well. Parang sa cylinder head ng mga naka DOHC na galant na nakabaon ang spark plug sa malalim na butas. Kung long nose o vise grip, yung dulo na lang ang makakagat, baka mabali lang ang ceramic casing pag pinihit. Ginamitan ko ng stanley extended socket, 1turn lang at matigas na hindi na maikot.
    Bro, talked to our trusty mechanic who handles multicabs, pwede raw very small amount of wd40, have it soak your spark plug overnight, then try to remove the spark plug. He has done this before.
    Jul 2003
    do not use vise grips or long nose pliers in removing your plugs or any bolts/nuts. use the right tool for th job.
    Sometimes the sparkplugs got some corrosion built up at the end of the thread, the one protruding into the cylinder. You may try to remove it by alternately loosening it a bit then tighten it, and continue alternating between cw and ccw turn.
    when you install a new plug do not overtighten it. To install it, hand tight first the plug and when you feel that the plug has bottomed, tighten it using the wrench handle an additional 1/4 turn.
    Mga Bro,
    Thanks for the input. Try ko yung mga sinabi nyo.
    bro try mo vacuum .. joke hehe..
    sprak plug wrench kaya na may extended lever or handle ..
    btw, ilang years naba yang spark plug sa engine mo? baka nag loose na nga ..
    Makahiram nga ng vacuum hehehe
    1 year na nung nilagay current spark plugs, umaandar pa at wala namang problema. Gusto ko sanang i-check kaso ito na nga ayaw matanggal. Spark plug wrench din gamit ko pero hindi ko pinupuwersa at baka lalong magka problema.
    Quote Originally Posted by Bochekokik View Post
    bro i think you should consult a good mechanic na ..
    Try ko muna yung WD40 at counter pihit technique na advise ng mga kasama natin. Pag ayaw pa rin.... its time to call a friend na
    Aug 2007
    Quote Originally Posted by s_quilicot View Post
    dalhin mo na lang sa talyer kung ayaw pa din matanggal.. yun ang magandang paraan.
    Aug 2004
    Probably the best way, pare. I've had spark plugs stick before... you can take a small hammer and lightly tap it against the spark plug wrench to try and loosen it, also... tap, ha... not whack.
    sir, pag natanggal mo na yung plugs, lagyan mo ng anti-seize compund yung thread ng ikakabit mo na plug para nde na ulit ma stuck.
    Quote Originally Posted by JiggeR671 View Post
    Bro, ano yung label nung anti-seize compound? San kaya ito available?
    Jan 2008
    tama pukpukin konti pero mahina lang. gamitan mo rin ng socket wrench.
    Ok na, natanggal na.
    Konting babad sa WD40 overnight, then 1/4 pihit cw-ccw, so on and so forth, and then viola, tanggal na.
    congrats bro .. amzing job haha
    Oct 2007
    ako yon copper grease nilalagay ko, yon pang brakes. mga 2mm bead sa thread. ito rin nilalagay ko sa slide or any mating surface.
    if you can find brake grease, a 20ml tube will last a very long time if you will just use it on threads and on your gun.
Ayaw matanggal spark plug
