Results 1 to 10 of 18
October 15th, 2017 02:45 AM #1
Not sure if this is ok. Normally fans are behind the radiator/condenser. Any comments or thoughts on this setup?
upload images
October 15th, 2017 01:53 PM #3
for the condenser? direct cooling; that would be fine. madami naman na gumagawa niyan bro.
October 15th, 2017 03:55 PM #4
thanks for info.
October 15th, 2017 04:17 PM #5
sa MS sir stock nasa harap. bro zix added an auxillary fan sa harap din...
October 15th, 2017 04:32 PM #6
meron mesh in between? I think factory setup is behind kasi in case the fan blade cracks.. the shards will not damage the radiator.
- 54,301
October 15th, 2017 05:51 PM #7
October 15th, 2017 10:05 PM #8
I remember '90s cars had fans in front... Another behind the radiator...
Fan in front is connected to the A/C compressor...
Radiator fan is linked with the thermostat...
I think '90s Sentras have 2 big fans behind the radiator... Instead of the front and back set-up...
- 54,301
October 15th, 2017 11:08 PM #9many rear-drive cars of 90s and older, had fans behind the radiator. but to some owners, the aircons and engines got hotter in heavy traffic.
they added auxiliary electric fans in front of the radiator. the set-up resulted in cooler aircon and engine, and did not result in engine overheat when off.
i had one, myself.
my '97 sentra had two aux fans in front. and they gave me a big headache.
for a long time, i could not find the source of my engine's tendency to overheat in traffic. until an oldtimer mechanic showed me just how weak my old fans' airflow was, compared to the new ones'. we had to do it side by side, as my old fans still managed to push out considerable oomph.
strangely, the aircon was still acceptably cold. but it did get factory-arctic-cold, after replacement of the old aux fans.Last edited by dr. d; October 15th, 2017 at 11:25 PM.
- Aug 2017
- 321
October 16th, 2017 01:23 PM #10
Yes, it's a common remedy especially for "non-tropical designed" cars.
The aux fan infront of the engine typically draws air towards the engine, and the 2nd aux fan behind the bumper must draw air towards the engine as well... Ergo, one air flow direction towards the engine.
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
