help! it's been a week, i observed my 97 honda city has increased fuel consumption from 9-10km/liter city driving to 6-7km/liter without anytyhing done with the engine and the entire car. what could be the culprit???
Maybe one of the spark plugs got fouled. When is your next maintenance due?
SIRS actually i just got this car last april 24. i replaced in two days within my possession all the plugs, air filter, timing belt, crank/cam shaft, velocity joints, radiator, accelerator and cable. everything went fine until last week. the fuel consumption went up...also to mention, i cleaned the throttle body, IAC is fine. im suspecting it could be the fast idle screw that's the culprit coz i found it closed tight and when i put it back after cleaning, i closed it tight as well. idling and running perfectly normal though...what do you think? by the way, i change gear (ease up the pedal,it's A/T) before reaching 2000rpm...
