Results 1 to 7 of 7
    Jan 2011
    mag change atf oil sana ako sa isuzu crosswind A/T via dialysis system. ansabi, bili ng sariling atf para makamura.. nakabili ako isang karton, 12 liters lahat.. problem is, mali daw yong nabili ko.. ang nabili ko yong shell spirax s1 atf TASA. ask lang ako ng guidance sa mga guru dito. maling atf ba talaga ang naibigay sa akin ng sales lady?
    Sent from my SM-G610Y using Tapatalk
    Apr 2010
    the required ATF should be indicated in your manual. pero kung wala nang manual, try to give casa a call or puntahan nyo mismo then state your vehicle's year and model, sasabihin nila yung compatible specs ng ATF na pwede sa inyo. or hingin nyo na lang yung mismong bote then picture-an.
    wild guess lang it's compatible with Dexron 3 or Mercon which is very common, oldschool naman AT tranny nyan i think
    Quote Originally Posted by ParticleX View Post
    wild guess lang it's compatible with Dexron 3 or ATF which is very common, oldschool naman AT tranny nyan i think
    "when in doubt, buy from the casa."
    the purchase will probably be more expensive, but it will be for several tens of thousands of worry-free kilometers' use.
    Apr 2010
    i will be having the same scenario kasi about a year now
    toyota's T-IV ATF is very expensive at around 500+/L so masakit sa bulsa, drain and fill requires about 3 to 4 liters, kaya naghahanap ako ng compatible with that ATF
    try banawe.
    them gurus seem to know "what works, what doesn't work" on our cars.
    Jul 2016
    2 weeks ago nasa isuzu casa ako. Nakita ko gamit nila caltex atf. Hindi naman yata maselan at ng crosswind. Sa alterra gamit ko petron atf more than 100k na natakbo dipa naman nag ka problem.
    Sent from my SM-J500G using Tsikot Forums mobile app
    Jan 2011
    thanks so much sa reply...
atf for crosswind
