Results 1 to 14 of 14
    Jul 2012
    Found this device being installed on different vehicles mostly diesel-powered. May nakapag-try na ba sa inyo dito? Ano naging effect if any?
    Jul 2012
    Apparently ang effect daw is reduction in smoke emission and nakakalakas daw mg hatak.
    Quote Originally Posted by hondazek View Post
    errr... what device, sir?
    would you happen to have a picture? a description?
    Jun 2005
    another one of them air bleed device. khaos seems to be the most popular.
    funny, when they refer to "pollution" they all refer to the black smoke and not CO and other hydro carbons.
    and they all claim to increase power while saving money and the environment.
    Jul 2012
    Ito sirs yung link nung product: https://www.facebook.com/efgenterprises
    Nakakita rin ako ng mga videos showing the effects on the emission. I also know some friends who used it in their Crosswinds, nawala talaga yung smoke eh.
    Jul 2012
    Tingin nyo *sirkosero hindi rin effective ito? Sorry ha newbie lang ako sa sasakyan.
    Aug 2004
    BS.
    Just an air-vortex device.
    It's possible they do other stuff during the installation to make it appear like it works, but typically, an air-vortex device does nothing.
    If you want less smoke on a modern "Euro" emissions Crosswind, a simple blocking of the EGR works.
    BS.
    Jun 2005
    getting a proper tune up wil give you the same, if not better result
    May 2009
    ipa-myth bust natin ke marty at moog....hehe
    dito pa lang sa tsikot, busted na.
    May 2009
    tsaka mas malaki ang improvement sa emission using 2T kung opacity lang din usapan.
    Feb 2012
    Pero parang may sense naman kasi ang effect niyan ay mag swirl yung hangin na papasok sa combustion at yun ang main goal ng mga karerista ng motor hehe Ewan lang sa mga 4 wheels hehe
    Aug 2004
    Quote Originally Posted by sotel View Post
    Swirl is beneficial, but you need the vortex generator to be position right inside the intake manifold, right before the port (and one per port) for it to work properly.
    Jul 2012
    Pero how do explain sirs yung sudden loss ng dark emissions sa mga kinabitan ng ganito? Saw some videos kasi and even knew people who actually had this device installed on their vehicles at sabi nila nawala daw talaga eh.
    Aug 2004
    Tactic used in Khaos Super Tubo... errh... Turbo Charger installs before. Either a tune-up and oil change along with the installation... or a good spray of diesel injector cleaner during the disassembly.
    Hell... give me time with the car, and without installing anything, I can reduce black smoke simply by plugging up the EGR valve.
    Which is also a possible tactic by the installers. And which can be done without installing a cheap piece of tin in the intake.
    If you want to improve your diesel's emissions, you can simply take it to a reputable garage and they will give a no-bullsh*t EGR blanking plate that doesn't work on fairy dust.
    If you want to be funky and install some cheap tin fins inside your intake where loose pieces can be dislodged and drop into your intake valves... go right ahead. If you really want to "sakal" your engine for the sake of fuel economy and emissions, you can simply DIY a blanking plate with tiny holes to slow down the intake air...
Anyone tried using EFG (Environment Friendly Gadget)?
