Results 1 to 9 of 9
November 15th, 2005 11:23 PM #1
hello question...
anong ibg sabihin pag kumakatok yng makina?...kahit mataas na yng rpm pag nag-change ng gear kumkatok parin
- what does this mean?
- ways to fix?
- how much gastos?
carburator pala ang engine....
TIA!!
November 15th, 2005 11:42 PM #2
-wala sa timing
-tuneup or DIY
-mura lang. pang mcdo mo lang
alternatively,baka wala na sa lapat ang cylinder head etc. this will cost more...pakita mo na lang sa mekaniko na competent
November 15th, 2005 11:59 PM #4
katok or tope = engine knock = pinging or hammering = predetonation. it sounds like there's a hammer inside the engine, and that's exactly what it does. predetonation acts like a hammer on the pistons, causing major damage to pistons, connecting rod, crankshaft, cylinder head and cylinder liners.
causes: too low air/fuel ratio, too low fuel octane used, bad ignition timing.
fix: adjust carb so a/f ratio is not lean, use higher RON fuel, adjust ignition timing. cheap lang yan, cost of a tune up kung need ng adjustment ang carb or ignition timing.
but the cost of fixing damage from engine knock is high. spell "overhaul", o-v-e-r-h-a-u-l, overhaul. mura pa din? spell "new cylinder head", or how about "change engine"? wag na haba nun hehehehe...
November 16th, 2005 12:03 AM #6
iba connotation namin ng tatay ko pag kumakatok/kakatok makina... parang mag bogged down yung engine ang dating samin...so, in short
laki gastos
- May 2005
- 286
November 16th, 2005 12:06 AM #7Yan din ba yung kapag cold start, malaki ang standard deviation ng fluctuation ng revs per minute pero kapag medyo mainit na nawawala na?
November 16th, 2005 10:17 AM #8Originally Posted by aann
baka may tao sa loob. pagbuksan mo lang. j/k.
seriously, nasagot na nila lahat....
November 16th, 2005 12:15 PM #9Originally Posted by happy_gilmore
Thanks for the replies!
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
