Results 1 to 5 of 5
- Aug 2003
- 9,720
July 6th, 2006 10:11 AM #1hi guys! nasiraan ung optra ng kaopisina ko. i think he'd had it for about 3 years na, ung 1st batch with the, um, unusual grill design, with about 20k+ on the odometer. naisolate ng mekaniko na ung fuel pump nga ang me problema -- me kuryente namang pumapasok, pero di siya gumagana.
nung pinahanap namin sa auto shop, 14.5k daw! i can only assume na orig ung pinagtanungan niya. me available na kayang replacement for this? me compatible/interchangeable parts kaya ito sa previous kia/other korean cars?
and talagang ganun ba ang presyo ng fuel pump these days, even for jap cars?
thanks
- Nov 2003
- 64
July 8th, 2006 02:31 AM #3Originally Posted by badkuk
- Oct 2004
- 278
July 8th, 2006 04:59 AM #4try nya ipakalas dun sa mechanic yung fuel pump, malamang merong similar na jap fuel pump nyan.... anyway, the circuit opening relay should work fine with any type of fuel pump naman basta yung wiring ay positive-negative lang... try to get one na kapareho ng size para medyo kapareho din yung pressure at discharge volume...
kung yung pump lang mismo, mga 1k lang yung mga jap surplus sa suking surplusan...
July 8th, 2006 08:08 AM #5
newer gm vehicles have an electric fuel pump that comes as one piece. so when it goes dead, you have to replace the whole assembly. dont buy replacement. it is not durable. though, if you can find a japanese brand replacement, it will do. you can also find opel parts on those gm parts supply stores in binondo such as nemerson and thunder automotive.
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
