Results 1 to 13 of 13
    may relationship ba to?
    these last 2 -3 oil changes... hindi ko na dinadala sa casa yung ranger ko... sa planta na lang namin.. tutal may motor pool naman kami dun.. i just buy the parts that need to be replaced and have them do the work... but dun nga sa last 2 - 3 oil changes... napansin ko na tumataas ang consumption ng fuel per km... it's posssible that my driving habits have changed.. but sa ramdam ko eh di naman gano... although i'm not sure kung anong oil ang ginagamit nila.. dati sa casa they use either shell or mobil... what's the best oil ba for diesel engines?
    depends on the viscosity of the motor oil used. The lower viscosity will give better milage at cost of slightly less engine protection
    Dec 2002
    Try changing your air and fuel filter. What oil brand and viscosity are you using?
    Quote Originally Posted by wowiesy
    Does engine oil affect fuel consumption: YES!
    Whats the best oil for diesel engines: Follow manufacturer recommended oil, but if i were to choose between Mobil and Shell - i'd go with Mobil 1.
    napansin ko din yan, kapag outside of casa ako nagpa oil change, gamit ko Mobil Delvac MX, medyo bumababa ng konti ang mileage ko. sa casa ang gamit nila Fuchs or Fusch.
    Signature
    Feb 2004
    maka-singit na nga po..
    ano ba magandang engine oil at viscosity para sa 1.6L sedan?
    Quote Originally Posted by butchokuy
    Caltex Havoline Energy Synthetic 5W-30 (but check your manual if the said viscosity can operate within the temperature range here as this may vary from engine to engine).
    Apr 2005
    I prefer mobil 1 0w40 with supersynt or Castrol Formula RS 0w40 for 1.6L sedan
  9. #9
    Quote Originally Posted by mistah
    How much is the mobil1 0w40? and where is it available? thanks.
    Dec 2004
    Dyan sa Servitec Sucat, malapit sa Lopez...mas mura ang Mobil1 nila...P2100/4 liters.
    Nov 2003
    check my sig for the mobil 1 oil
    Mar 2005
    Quote Originally Posted by speedyfix
    Speedfix, how much benta mo kapag mobil1 0-40w lang?
    Nov 2003
    text me nalang
engine oil affects fuel consumption?
