Page 5 of 6 FirstFirst 123456 LastLast
Results 81 to 100 of 116
  1. utopia45 Guest
    #81
    Sir Auto_Xer,
    Is the 20w-50 oil icon is using on his accord before mineral, semi, or synthetic? Thanx.
    #82
    mobil delvac
    #83
    utopia45,
    It's semi-synthetic, it's the same oil we use on our past turbo rallye car & current NA rallye/x car, as well as our other vehicles.
    #84
    Castrol
    I believe it's synthetic...
    Dec 2002
    #85
    1) Mobil 1 full synth for gas engines (5w50 and 0w40 available locally, i've also used 15w50 tri-synth from US)
    Tried LiquiMoly 5w40 full synth- got good mileage.
    2) Mobil Delvac 1 full synth for diesels- 5w40- the best full synth for diesels AND gas too! API rating CI4, CH4, SL, SJ.
    Jan 1970
    #86
    I am currently using Mobil 1 with SuperSyn 0W-40 API SL (from the U.S.) for the Mazda 323 Familia 1.6L, Corolla 1.6L 4A-FE, and Adventure 2.0G. No complaints, very easy on starting, and very little consumption in-between oil changes. Several notches superior to Mobil 1 tri-synthetic formulation. If you have access, go for it.
    Dec 2002
    #87
    ondoy,
    Just got mobil 1 supersyn 10w30 from US. Will use it on honda CRV.
    How much is the mobil 1 0w40 in the US? What's the landed cost in the Phil?
    Jan 1970
    #88
    jackaroo,
    Sent you a PM.
    Apr 2005
    #89
    I only use mobil 1 on my 1998 elantra. the best fully synthetic engine oil.
    #90
    Revive ko lang po yun thread na ito. Sa panahon ngayon anu ang magandang oil na gamitin, yun malaki matutulong sa fuel consumption at performance ng kotse? mag-chachange oil na kasi ako in a few weeks. I'm using a Hyundai Sonata 2000 GLS pala
    #91
    shell helix semi-syn for gasoline
    shell helix full-syn
    shell helix
    shell rimula-x for diesel
    since i started driving in 1986, i've been using the above.
    #92
    Quote Originally Posted by xfire View Post
    shell helix
    sir, anu po ba difference ng shell helix semi-syn for gasoline at shell helix full-syn? may advantages po ba between the 2? Unleaded nga pala yun gasoline na gamit ko
    #93
    Quote Originally Posted by Vinsanity View Post
    viscocity and price.
    before, i'm hard core full-syn. but, with the current high prices of oil products, i use semi-syn.
    #94
    shell helix (blue) semi-synth 10w/40 or castrol gtx 20w/50 pag budget
    #95
    anu po ba current prices nila? yun sa Castrol at Shell Helix (full synth/semi-synth)?
    Ito po ba lahat ng Shell Oils na available?
    http://www.shell.com/home/Framework?...ga_0312.html#0
    #96
    Current Price of Castrol Magnatec 10W-40 Semi-Synthetic 4 Liters is P1,100. kakachange lang last tuesday...
    we use:
    Castrol Magnatec 10W-40 Semi-Synthetic for Toyota 3C-TD
    TOP 1 15W-40 Fully-Synthetic for Mitsubishi 4D56-TDI
    One oil manufacturer claims that "some people in the industry use multi-viscosity as if it means the same thing as multigrade. An oil cannot be multi-viscosity, but it can be multigrade by meeting the viscosity requirements for SAE 30, 40, 50 or 60 and one of the sub-zero "W" viscosity requirements. At one time, some oil companies labeled oils SAE 10W, 20W30—as if the oil could be 10W and 20W at the same time. This is impossible because 10W is measured at -20 degrees C and 20W is measured at -10 degrees C, which eliminates the multi-viscosity theory."
    When you see 10W-30 on a quart of oil, it means that it acts like 10 weight oil when it is cold (the "W" means winter, say -10^C), but acts like 30 weight oil when hot (100^C). This is not to say that it is actually thicker when it is hot. Hot 30 weight oil is thinner than cold 10 weight oil. Even so, it still helps provide the benefits of both types of oil depending on its temperature. So 0W-30 oil acts like 0 weight oil when cold, but maintains a 30 weight viscosity when hot.
    unless your engine is in bad condition, use a light weight oil. so friction won't be too hard on your engine at the coldstart... use heavy oil and it would cause low RPM on early morning start-up.
    Read the Labels na lang to make sure your vehicles fit the category...
    Feb 2006
    #97
    guys, tanong lng, yung suki ko kasing mekaniko advised me to just use shell helix super (yellow), my car's 12 yrs old. masama na daw kasi kung gagamit pa ko ng helix plus or ultra. should we really consider the age of the engine in considering whether to use synthetic or mineral? i use helix, yung super kasi(yellow) mineral lng sya.
    #98
    based po sa website ng Shell:
    Helix Yellow nga ang advisable gamitin ng car mo.
    Oct 2003
    #99
    my brothers are using motul h-100 10w-40 fully synthetic motor oil. 380php/liter.
    Sep 2004
    #100
    i tried using enoc oil on my honda and pansin ko smoother ang idling and acceleration.
Ano pong ok na Engine Oil? Survey na din, ano oil nyo?
