Results 1 to 10 of 14
February 13th, 2006 10:05 AM #1
Ano ba ang usually cause ng loose compression sa makina (gas engine)? At ano ang mga early signs?
thanks!
- Sep 2005
- 103
February 13th, 2006 10:35 AM #2Opinion ko lang po ito, im not saying na sigurado ang mga ito.
-Overheating
-worn out valve seals
-worn out piston rings
-age of car
-delayed oil change
-driving habit
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Sep 2005
- 103
February 16th, 2006 09:54 AM #4Speedyfix, ask ko lang po.
yung car ko kase almost a year pa lang nung ma overhaul kaso minsan mausok sya:
pinalitan naman piston rings, valve seal and guides. ano kaya cause nito?
TIA
February 16th, 2006 07:48 PM #5Originally Posted by Betz
February 16th, 2006 10:04 PM #6Originally Posted by city
- Nov 2003
- 3,849
- Feb 2006
- 3
February 17th, 2006 02:24 AM #8Mga pre pasensiya na ...kailangan ko lang ng tulong talaga...2 yrs ko nang problema kotse ko...MITSUBISHI GALANT 1992 AUTOMATIC TRANSMISSION MPI....pag nag air-con ako masyadong bumababa ang idling..nanginginig...sobra...3 yrs ko na nabili yon..noon di ganoon...baka pwede patulong naman..pls..tinaaas ko ang idling pero pag nag air-con na taas baba...lakas pa sa gas...pls. patulong...sakit na ulo ko
February 17th, 2006 06:04 AM #9Originally Posted by gorio31
siya nga pala mga sir, paano nga pala ang process nang pag check nang compression? di ba may 2 type yun? saka, tama ba, wala nang engine brake kapag worn-out na ang piston rings?Last edited by ian_rex; February 17th, 2006 at 06:06 AM.
- Sep 2005
- 103
February 17th, 2006 10:42 AM #10Speedyfix
ang nag overhaul kase ung dati naming trusted na mechanic. sya kase nag me maintain nung old car ni erpats na lambda. hindi ko kase masyado nabantayan. sa palagay mo ba dapat ulit pa buksan engine ko o makuha pa sa top overhaul?
TIA
Mileage varies with LED bulbs on multi-reflectors. On the 1st gen Innova with the last facelift,...
2013 Mitsubishi Mirage
