Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Ano ba ang usually cause ng loose compression sa makina (gas engine)? At ano ang mga early signs?
    thanks!
    Sep 2005
    Opinion ko lang po ito, im not saying na sigurado ang mga ito.
    -Overheating
    -worn out valve seals
    -worn out piston rings
    -age of car
    -delayed oil change
    -driving habit
    Quote Originally Posted by Betz
    -Overheating
    -age of car
    -delayed oil change
    -driving habit
    ..correct ka dyan brader,.. mostly nga worn out piston ring/s.. one of the signs? hmm? some or many other vehicles can experience less top-end power,.. paghumataw ka, parang bitin na humatak,..less torque pati!..imho!
    Nov 2003
    mostly busted piston rings.
    Sep 2005
    Speedyfix, ask ko lang po.
    yung car ko kase almost a year pa lang nung ma overhaul kaso minsan mausok sya:
    pinalitan naman piston rings, valve seal and guides. ano kaya cause nito?
    TIA
    Apr 2005
    Quote Originally Posted by city
    thanks!
    worn out piston rings is one cause of low compression. early sign is white smoke sa exhaust pipe.
    Nov 2003
    who did the overhaul?
    Feb 2006
    Mga pre pasensiya na ...kailangan ko lang ng tulong talaga...2 yrs ko nang problema kotse ko...MITSUBISHI GALANT 1992 AUTOMATIC TRANSMISSION MPI....pag nag air-con ako masyadong bumababa ang idling..nanginginig...sobra...3 yrs ko na nabili yon..noon di ganoon...baka pwede patulong naman..pls..tinaaas ko ang idling pero pag nag air-con na taas baba...lakas pa sa gas...pls. patulong...sakit na ulo ko
    Jan 2004
    Quote Originally Posted by gorio31
    pag naka-aircon lang ba sir? baka madumi ang throttle body mo. search ka tungkol sa throttle body cleaning.
    siya nga pala mga sir, paano nga pala ang process nang pag check nang compression? di ba may 2 type yun? saka, tama ba, wala nang engine brake kapag worn-out na ang piston rings?
    "servo" yan brader, sakit talaga ng ibang mitsu galant (from 6g & 7g models) & lancer itlog.
    Maybe this site can help you with your prob: For more info about this, hope that, this are the answers to your question:
    click link:
    MITSU SERVO TROUBLESHOOTING GUIDELINES
    good luck brow!
    ATTENTION: THOSE OWNERS OF MITSU GALANTS 6G & 7G MODELS, LANCER ITLOGS, MOST ESPECIALLY WITH IDLING & SERVO PROBLEMS, THIS WEBSITE INFO. IS FOR YOU GUYS!!!.. WELL JUST READ THE GIVEN THREAD/POSTS, AND YOU'LL ABLE TO MEET YOUR ANSWERS REGARDING THE PROBLEM,..HAPPY SURFING,..TY!!.. again, click link above.
Ano ba mga causes ng loose compression (gas engine)?
