Results 1 to 13 of 13
    Apr 2004
    lovelife body...
    kotse ng misis ko. 67,000km sa odo. absolutely stock and still sariwa. the only thing i've done is replace a stuck up a/c compressor with a surplus compressor. the a/c tech then said ayaw na mag automatic so nilagyan ng ibang thermostat that clicks on and off.
    ito kya yung cause ng high FC? measured it 3 times already, it's only 4-5 km/lit. i might as well be driving an expedition.
    at wala pa hatak.
    something's wrong i know it... changed the filters, oil, spark plugs, alignment... ang hindi ko na lang nagagawa yung pa adjust yung valve tappets sa toyota, which the service advisor said was not unnecessary (?).
    any ohter ideas? short of removing the temp a/c thermostat?
    May 2005
    ang coimpressor pag hindi tugma sa load ng makina talagang malakas sa gas, either overworked sya unnecesarily or underpowered yung makina relative sa compressor, pa check mo muna, at yung sabi ng SA mo?
    "said was not unnecessary (?)."
    pag ganyan necessary pala yun....
    Sep 2004
    Hehehe, a clear case of double negatives, leading to a positive result.
    Re: fuel problem, have another A/C technician double check your compressor. For sure, nandun ang problema.
    Aug 2005
    kamusta naman ang FC kung hindi ginagamit ang AC?
    Apr 2004
    hehe. sorry i meant "not necessary"... typo my bad.
    FC without a/c seems the same, but i haven't measured it yet. pero prior to the installation of the surplus compressor, ganda yung FC nya. nasa 9-10. yun nga parati namin gamit kasi matipid.
    binalik ko na sa nagkabit sabi nya pareho lang daw sa lumang compressor yun, only diff was, surplus japan yung compressor. i'm guessing na baka compressor ng camry yun eh, kasi ang lakas talaga: bilis at consistent yung bomba ng freon kasi ang lamig lamig, beats the old old compressor even when it was new.
    yun nga lang, lakas talaga sa gas.
    may differences ba ang compressor power across all corolla model ranges ng toyota? e.g., higher power yung sa 1.6 engine vs. 1.3 engine? para kasing pare-pareho lng itsura nila sa akin eh.
    Baka malaki ang inilagay na compressor sa iyo bro. The size of the compressor also affects fuel consumption . . . Compare mo sa iba repakol ang size ng compressor.
    Oct 2007
    walang kwenta ang mga surplus compressors kasi you will just need to replace every time it becomes defective. palpak yang mga yan whether it's from banawe or evangelista. nakadalawang palit kami. yung 1st comp. namin tumatagas ang freon. yung 2nd comp. di rin namamatay para mapahinga yung engine. the same
    problem that you have right now - an aircon that does not automatically turn off
    after a few minutes of use. the aircon must also automatically turn off when you accelerate fast after pressing the gas pedal hard. that's why we opted to install a brand new compressor. talagang magastos yan sa gas kasi the engine no longer rests when it's turned on. mga 20thou nagastos namin kasi we had to replace some parts which were probably affected by the dysfunctional compressor. mitsu lancer auto namin
99 corolla xe 1.3 atrocious gas mileage
