Results 1 to 10 of 13
March 28th, 2008 07:49 AM #1
lovelife body...
kotse ng misis ko. 67,000km sa odo. absolutely stock and still sariwa. the only thing i've done is replace a stuck up a/c compressor with a surplus compressor. the a/c tech then said ayaw na mag automatic so nilagyan ng ibang thermostat that clicks on and off.
ito kya yung cause ng high FC? measured it 3 times already, it's only 4-5 km/lit. i might as well be driving an expedition.
at wala pa hatak.
something's wrong i know it... changed the filters, oil, spark plugs, alignment... ang hindi ko na lang nagagawa yung pa adjust yung valve tappets sa toyota, which the service advisor said was not unnecessary (?).
any ohter ideas? short of removing the temp a/c thermostat?
March 28th, 2008 07:58 AM #2
ang coimpressor pag hindi tugma sa load ng makina talagang malakas sa gas, either overworked sya unnecesarily or underpowered yung makina relative sa compressor, pa check mo muna, at yung sabi ng SA mo?
"said was not unnecessary (?)."
pag ganyan necessary pala yun....
March 28th, 2008 08:20 AM #3said was not unnecessary (?)."
Re: fuel problem, have another A/C technician double check your compressor. For sure, nandun ang problema.
March 28th, 2008 10:55 AM #5
hehe. sorry i meant "not necessary"... typo my bad.
FC without a/c seems the same, but i haven't measured it yet. pero prior to the installation of the surplus compressor, ganda yung FC nya. nasa 9-10. yun nga parati namin gamit kasi matipid.
binalik ko na sa nagkabit sabi nya pareho lang daw sa lumang compressor yun, only diff was, surplus japan yung compressor. i'm guessing na baka compressor ng camry yun eh, kasi ang lakas talaga: bilis at consistent yung bomba ng freon kasi ang lamig lamig, beats the old old compressor even when it was new.
yun nga lang, lakas talaga sa gas.
may differences ba ang compressor power across all corolla model ranges ng toyota? e.g., higher power yung sa 1.6 engine vs. 1.3 engine? para kasing pare-pareho lng itsura nila sa akin eh.
March 28th, 2008 11:08 AM #6
Baka malaki ang inilagay na compressor sa iyo bro. The size of the compressor also affects fuel consumption . . . Compare mo sa iba repakol ang size ng compressor.
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 3rd, 2008 09:38 PM #7normally kahit gaano kalaki compressor mo di ka naman dapat aabot sa ganyan milage. have the carb checked. kung wala ka hatak it's normally that which causes it kung maayos naman timing and tappets mo.
- Nov 2003
- 3,849
April 9th, 2008 07:34 AM #10
Neither's mine. 3 yrs old and no issues whatsoever. Initial 2 PMS lang sa casa, the rest is OC...
Suzuki JIMNY [merged threads]
