Results 1 to 10 of 13
- May 2006
- 141
October 11th, 2006 04:46 PM #1Mga Sir,
I need to replace my air filter ok lang po ba Replacement and not OEM? how much po kaya replacement versus OEM? also kung kailan dapat palitan or tinatgal if ever replacement ang gagamitin ko.
nga pla sir yung pinaka filter lang po not the whole air filter assembly
My ride is a Honda Civic VTI 2000.
TIA
God Bless!
October 11th, 2006 04:51 PM #2
sir, EK Civic ba yung model nang ride mo? i never heard of replacement filters. aftermarket lang. K&N would be a good buy. medyo expensive, but washable and good for 100,000 miles.
October 11th, 2006 04:55 PM #3
I use replacements. Less than half the cost of the OEM filters for my Pajero or the Vitara so I can afford to change more often. Replacement air cleaner is less than Php300.00 (big filter na ito).
Don't know if its the same case for Honda.
October 11th, 2006 05:00 PM #4
nakaka-void po ba ng warranty yun sir otep? and saan po nakakabili nyan?
October 11th, 2006 05:00 PM #5
October 11th, 2006 05:04 PM #6
Autosupply ni GlennSter ang pinakamalapit na matinong auto supply dito sa akin. Dun ako kumukuha ng consumables ko.
Siyempre it will void your warranty if they find out. Off warranty naman lahat ng alaga ko (except the Picanto).
Mga hindi kilalang brand lang ito like Seiwa, etc. Yung sakin nga pang-Isuzu Elf ang nakalagay sa box.
MB100 at Starex, Php300.00 din ang replacement air filter kina Glenn. Yung Vitara Php280.00. Hindi ko na tinawaran, madami naman nang natulong shop ni Glenn sa akin.
Nung binuksan ko yung air cleaner ng Mercedes to check the filter, same brand din as yung replacement air cleaner ng Starex ang nakalagay.
October 11th, 2006 05:13 PM #7
Not sure if the SiR and VTi have the same filter. Para kasing magkaiba sila ng air intake assembly. The SiR resembles that of the 2000 CR-V. For the Civic SiR, the original air filter costs 750, replacement costs 250. Not sure if there are differences in terms of performance.
October 11th, 2006 05:14 PM #8
Kahit pala three times more often mo palitan hindi ka pa din lugi. hehehe. Hindi mo na kailangan mag-buga pa ng hangin sa gas station. Salpak na lang ng salpak. Parating fresh.
- May 2006
- 141
October 11th, 2006 05:21 PM #9
October 11th, 2006 05:22 PM #10
At least Php5k ata ang K&N kasama na yung plumbing (tubo). Nasa Php850.00 pa din ba ang cleaning kit up to now?
high idle RPM at engine start
