Results 1 to 8 of 8
    Aug 2003
    hey guys, i have a simota air filter (plate type). was wondering kung paano linisin yun medyo madumi na ata eh.
    may nakita ata ako na cleaning kit for this? how much kaya yun?
    Nov 2003
    k&n cleaning kits are around 1000 and up. of course you could use simple water and soap pero doing so will remove the filters protective oil which keeps the dirt particles out of your engine. up to you tho. i say go with the cleaning kit!
    Aug 2003
    thanks pare. cleaning kit nga first option ko.
    Dec 2003
    meron simota cleaning & recharge kit mga 800+. 2 bottles un.
    mag tide ka nlng, den sprayan mo nlng ng wd40. no joke to ah..yung wd40 di pwede sobra sobra
    Nov 2003
    You can check this out at the AI website: http://www.autoindustriya.com/askgibs.php?id=112
    But how much WD40 should be enough? Paano ko malalaman kung hindi sobra ang pag-apply ko ng WD40?
    di pwede yung dripping wet..cguro mga basta medjo mukhang basa..
    Nov 2003
    i doubt this will be as effective as the cleaning kit pero kung tipid yung habol mo then you can't get much cheaper than this
air filter DIY
