Results 1 to 15 of 15
    Aug 2007
    good morning. car is a 99 honda civic vtec. it is due for an oil change. it uses honda's (casa) LEV SL 10W30 oil for its engine. i want to use non-casa oil na fully synthetic. driving style is easy driving lang...
    what engine oil (fully synthetic) would you recommend i use as substitiute? by the way, im thinking of shell helix plus (blue)...would it be a compatible substitute for SL 10W30? what should i look for (details)when i buy a compatible oil? TIA
    Apr 2004
    what's wrong with casa regualr oil? i use it, it's cheap and has a good viscosity spread.
    castrol magnatec is 900/gallon sa banawe. IT IS NOT semi-synthetic, so regular lang yun. 10w-30 din sila pareho, pero sa castrol pagbili mo sa labas bbili ka pa filter (ingat sa fake), ppagawa mo pa sa labas (ingat sa sobrang taga maningil ng labor), and in general, it's more of a pain in the ass ngayo't may cheap oil chnge na sa honda.
    sa casa 850 all in na pati filter may libre checkup pa.
    your honda will take any oil within the 10w-30 to 5w-30/20. you can go 10w-40, or castrol's fully synthetic RS at 5w-40. NEVER run super cheap 20w-50. napakalapot nun. pang 1976 Saturn lancer box type na lang ang 20w-50 ngayon (shell yellow).
    only limit apart from the viscosity is cost of course. you pays your money and you makes your choice
    Jun 2006
    Royal Purple 10w30 sells for 550 per liter.
    Apr 2004
    you can use shell helix fully syn, 5w40, it's a thin grade 40, cst aroud 12.1...
    royal purple o red line kung gusto mo fully synthetic. may kamahalan nga lang eto. around 500-600 petot per liter
    Jan 2009
    I would assume that Honda oil gave you 10 trouble-free(?) years for your engine. If I were you, I wouldn't change my oil brand.... forever.
    Apr 2005
    Mobil 1/Royal Purple/Motul. Your choice.
    regular mineral / synthetic / semi-synthetic... unless you use your car for racing. they're all the same. though the synthetic variant enables you longer intervals in changing oil. It is way more expensive which just offsets it. pare pareho lang yan imho. what's important is you use the oil which matches your engine's requirement. viscosity and temperature rating better known as SAE rating.
    Aug 2007
    medyo cash-strapped lang kaya thinking of substitute for the honda engine oil...had honda SL 10W30 (regular/mineral oil yata nila ito) and twice put in their fully synthetic SL 5W40
    thanks pipol for the reply...
    Quote Originally Posted by silver streak View Post
    shell helix blue, i think is semi synthetic. shell gold ata yung fully synthetic.
    ako naman, i am recommending mobil one. costs around 750/liter.
    semi synthetic lang ang helix plus 10W-40 (blue) while fully synthetic ang helix ultra 5W-40 (gray). agree with volt, mas mura sa honda casa at less than 1000 lang all in. sa shell mahina 2K if you opt for fully synthetic.
    http://www.shell.com/home/Framework?...s_ga_0312.html
    how about enoc semi-synth oils? any users & feedback re: this brand?
    been trying to get the enios 10w-40s but it's now out of stock everywhere. i saw the ones w/ moybdenum but i don't exactly know what they are & how good they are
    If you're on a budget, just go for regular oil (Petron Ultron Touring, Shell Helix, etc). Even if you change every 5K it will still come out cheaper than using synth and protects your engine well too.
    bro kung budget meal bakit di ka na lang mag stick sa honda oil, kabibili ko lang sa honda magallanes ng oil vteclev mineral 6++ pesos only ang 4 liters
    May 2008
    mga sir saan ba nakakabili ng motul oils? may semi syn ba? magkano? mobil semi syn kasi gamit ko eh....thanks...wala ba sa ACE hardware yan?
advice: engine/motor oil to use
