Results 1 to 5 of 5
June 11th, 2009 09:19 AM #1
good day, ano kaya ang problema ng highlander ko?
every time na bagong pasok ang gear at di pa umaabot sa 1800rpm, parang pigil ang makina.
pero kapag sumampa na ng 1800rpm ang makina ramdam mo na yung power.
ramdam na randam yung pigil kapag bagong pasok sa 4th gear.
pero lahat ng gear pigil kapag below sa 1800 rpm.
kahit pigain mo yung accelerator parang di mo piniga.
ano kaya dapat kong gawin?
June 11th, 2009 03:11 PM #2
- Sep 2006
- 1,335
June 11th, 2009 08:37 PM #3Try these if your engine seems to run well, except for the low power complaint:
- Check accelerator cable adjustment
- Replace air and fuel filters
- Check EGR if equuipped
- Check injection pump and injectors
- Apr 2008
- 537
June 11th, 2009 09:08 PM #4
June 13th, 2009 12:05 PM #5
had it fixed already.
the injection pump just needed a calibration.
problem solved.
Before I sold my 2005 Innova after 12 years of heavily using it, I never changed its water pump.
