Check your fuel distribution & ignition systems (coilpack & leads). Fuel pressure can be checked by a fuel pressure gauge. Usually, there is a Schrader valve on the injector rail for this. Do this before proceeding so you won't unnecessarily be spending for the fix. Putting the key on position 2 w/o starting wakes the pump...if there is no change in pressure in switching from 1-2, check your fuel filter or your pump. Expect a messy process. The ignition system is external, way easier. Ask your shop, dealership or a friend w/ a similar car for help....borrow some of the working parts for quick testing.
