Results 1 to 20 of 20
    Jan 2009
    Brods,
    Tulong naman po. Sa dinami-dami ng mga mekaniko na pinuntahan ko, wala pang makapagsabi kung anu tlga problema. 94 GLi po auto ko..yung 1.6 ang makina. Masyado po xang malakas sa gas tpos maitim masyado ang usok. Eto na po mga nagawa namin.
    1) Full Changed oil
    2) Timing belt replacent
    3) Air Cleaner (??)
    Pero eto yung compilation ng mga sinabi nung mga mekaniko na pinuntahan ko.
    1) SERVO REPLACEMENT --> 9.5K (parts), 350 (labor)
    2) TOP OVERHAUL --> 15K aabutin
    3) INJECTION FUEL REPLACEMENT --> P4500 each x (4)
    4) THROTTLE Repair (??)
    Medyo gipit sa budget sir kaya hingin ko lang sana opinion nyo kung anu tlga problema. Thanks.
    Jan 2009
    Nga pala mga sir,
    1) Napalitan ko na din spark plug pero 1 week lng, maitim na naman.
    2) Napalinis ko na yung air filter nun.. pero ganun parin.
    3) Possible ba na nasa Fuel filter at Air filter ang problema at pwedeng umayos kapag pinalitan ko?
    Pasenxa na madaming tanong. salamat.
    pa compression test ka muna para malamang mo if ok pa ang piston and rings mo. also malalaman din if ok pa mga valves mo. kumakain naba ng langis? may lumalabas ba na usok pag inalis mo oil filler cap or dipstick mo?
    sa O2 sensor makikita kung bakit rich yan .
    sample scenarios are ;
    if the O2 sensor is lazy and stuck at low,the result will be rich ,why ? it's because the ECM was seeing it as a very lean condition.
    coolant sensor ,if it stucked at cold ( 4-5 v reading is considered cold) the computer will give more fuel .
    or if the vacuum is low the map sensor will make it rich too (if equipped)
    alot of things to be checked first before attempting to change any major parts suspected.
    the best thing to do is you to find a shop who is specialized in ENGINE DIAGNOSTICS not the shops who can only change parts and get lucky .
    otherwise you're at risk of getting the same results and that will be a problem.
    Nov 2007
    Dalhin mo kay Ray SArol sa san juan pa check mo dun, highly recommended dito sa forum yun pati na din sa mymitsu forum...
    Jan 2009
    Quote Originally Posted by kenzie View Post
    Sir, may contact number ka ba niya?
    Jan 2009
    Quote Originally Posted by bambino View Post
    Thanks brod, may pwede ka bang mai-recommend na shop who specializes in ENGINE DIAGNOSTICS? pahingi naman contact if ever. salamat ho.
    Apr 2005
    compression test muna. try speedyfix sa shaw near puregold. tsikoteer may-ari nun. si boss migs.
    Aug 2006
    Quote Originally Posted by afb_ramos93 View Post
    Raymond Sarrol - 09209252290
    Sa kanya ko nagpapagawa ng Lancer Itlog EX. Sa lahat ng nakilala kong mekaniko bukod sa Father ko bilib ako kay Raymond.
    Apr 2004
    baka nga overhaul (full) na yan...
    wag ka mag pa top overhaul...
    if i were to spend 5 digits sa engine ko i'd rather look around for a japan surplus engine, 4g63 or something. too many things can go wrong in an engine overhaul kasi, and mitsubishi has many engine types to choose from naman.
    Apr 2004
    well pa assess muna nya ang problema before considering drastic action like changing the engine. get a second opinion too.
    Nov 2016
    Help naman mga boss lancer gli auto q. 4g15 engine nya. Sobra lakas sa gas nag 4km per litter lang sya. Basesa mga mekanik n napag tanungan q nk baypass n ung hangin ng servo. Tornilyo n ang ang pang adjust sahangin. And palabas labas ang check engine nya. Pag n labas check engine n taas menor q.
    Mar 2013
    Fuel System
    Check filters. replace if dirty.
    Check fuel injectors. clean them via DIY or get to a shop.
    Check air filter. might need replacement also.
    Check MAF sensor.clean if dirty.
    Good fuel system?
    Check oil viscosity. Might be too thiick.
    Check engine compression.
    Check engine temp/radiators.
    sounds like you need top/overhaul. Pa compression test mo, and leak test na din para malaman kung top lang or overhaul na talaga.
    Feb 2009
    Check the fuel pressure regulator vacuum hose for leaks, check fuel pressure at idle and at 2000 rpm.
    Check engine vacuum at idle, should be between 17--21 inHg.
    Check voltage at ignition coil primary.
    Check ignition coil output( should be able to jump up to 3/4 inch to the engine block)
    If your fuel pressure is too high, the pcm is not able to adjust fuel pressure.
    If your ignition is weak it can not deliver sufficient voltage inside the pressurized combustion chamber.
    More than likely what you need is a tune up by a competent technician not a parts replacer and good quality parts
    Quote Originally Posted by Philipps0915 View Post
    nangyari ba ito overnight, or unti-unting tumataas sa daan ng panahon?
    Nov 2016
    Nung n bili q po ung sasakyan saka q łang n obserbahan n malakas sa gas. Pag inaadjust ung hangit medyo n tipid sya. Do i need tune up lang po ba. Ok naman po kc manakbo sasakyan malakas humatak. Malakas lang talaga sa gas ang problema q sa kanya and the check engine sign lagi n labas
    Jan 2017
    Ganyan din sakin Sir ang lakas sa gas.
    Honda Civic 97
    Kaka change lang ng engine. after 3 mos nag check engine. Bumili ako ng OBD II scanner kaso mali ang socket di pareho sa akin. So nag youtube ako, nakita ko yung oldschool na diagnostics, nalaman ko na 02 sensor sa ilalim problema. Sinilip ko patay ang sensor. Mukhang nagmadali ang pagkakabit sa engine ko. Pero Duda din ako kung yun nga dahilan baka meron p iba. San kaya pwde magpacheck yung reliable mechanic talaga na hindi nanaga. Salamat po!
    Jan 2017
    Number please Thank you Sir!
    May 2017
    mga sir maya katanungan lang ako. meron ako problem sa Lancer GTI 1992 EFI engine 4g15
    pansin ko pag idle siya ng lalaro ung ung idle nya. minsan nmn steady lang siya tapos may time na bumagbagsak ung idle nya tapos aangat ulit pero since nka muffler ako hndi swabe ung tunog nya sa muffler parang may misfire na tunog parang may maliit na naputok sa loob ng chamber pero okay nmn ang takbo ko. ska pag naibyahe ko na ng 4hours straight may time na biglang mamatay ung engine nya. tapos need ko mg wait ng 2-3 mins bago siya start ulit.
    additional problem is umaamoy ung gas nya sa tambutso. and every start ng engine meron white smoke na nalabas na amoy gas.
    hndi ako ng babawas ng oil and coolant. FYI
    salamat sa sasagot
94 Lancer Gli SOBRANG LAKAS SA GAS AT MAUSOK
