Results 1 to 14 of 14
    Apr 2008
    Hello im new at Tsikot.com. Since you guys know alot about cars and Manila, can anyone recommend a shop or garage with a good port & polish mechanic? Its for a Ford lynx ZMD 1.6 dohc or b6? for mazda cars. I am for quality works with no compromization. Salamat po.
    Dec 2007
    Quote Originally Posted by paullex View Post
    black sheep autoworks...eto po # nila 2400092 sila po ang mga kumakarera dati sa marcos highway ngayon puro track racing na sila at legal racing...
    san sila located? proven and tested na po ba sila?
    Oct 2007
    sir try mo sa KANZAI performance dito sa may araneta ave. recommended ng mga HCP'ers. di ko sure bro kung pwede yung tsikot mo dun kasi puro honda engine ginagawa nila dun. tested ko narin.ok naman!
    *EG,
    Contact numbers post ka naman,
    *Force,
    Dude, have called them up and for my ride, they have estimated the billed about 20-25k, all in na ang items sa kanila.. regarding P&P yan ha,
    Located cla sa:
    Black Sheep - Look for toochie
    Imelda Ave, Cainta RIzal. 2kms rightside.
    Anu ba tlga ang advantage pag nagpaP&P ka? and bkt ganun kamahal?
    Aug 2004
    Before you go into port & polishing, consider the engine itself. Port & polishing will only work if the rest of the engine, the intake manifold, the valves, the intake and exhaust modifications, etcetera, can flow enough to maximize your gains. My advice? Before doing this, research on the internet. Find out all you can about your engine, and where the possible restrictions are, before commiting to this. You might also find advice on what part of the cylinder head it is best to concentrate on when P&Ping.
    20-25k is about average. You can also try ATi (located on the road going to Tagaytay from Santa Rosa)... they test their work on a flow-bench to ensure even cylinder-to-cylinder flow.
    There are also a couple of others. There's Bernard (don't know his shop), who was recommended to me by Speedlab, and also the main man at AutoPlus, Pacho... they're pricier, but they take their time and study the engines they're P&Ping.
    Still, nothing is sure... and you sometimes run the risk of P&Ping too much, which will make your engine sluggish down low.
    Also consider engine management. If your stock computer cannot handle the extra flow properly, you will not maximize gains, either.
    For the threadstarter... join up at http://forum.fordclubph.com to find out more about your engine and what you can do to maximize its potential.
    Oct 2007
    Quote Originally Posted by mackkcam View Post
    *EG,
    *Force,
    Located cla sa:
    mack,
    kanzai performance
    landline: 482-2557
    look for mike: cp # 0917-5371677
Best Port & Polish mechanic.
