Results 1 to 15 of 15
    Jun 2008
    I have a 91 mits galant, and it's engine is 2.0 4G63A carbureted engine. pwede ko ba palitan yun cylinder head nya ng ECI multi? thank you
    Technically it can be done but it would be simpler and more reliable if a full engine swap is done.
    Jun 2008
    and ano yun mga kelangan ko bilihin and palitan and rough estimate ng gagastusin? salamat po ng marami
    Compatible engine complete with ECU, intake sensor and uncut wiring harness
    efi fuel pump
    For advise on pricing, you might want to call up shops like:
    SPEEDLAB
    871 Quezon Ave. Quezon City
    Tel. 376-4648, 376-4651 (look for Ferman)
    email: speedlab*speedlab.com.ph
    or
    SPEEDYFIX
    312 Shaw Boulevard, Mandaluyong City, Metro Manila
    SHOP - (02) 717-4202
    MIGS - (0917) 534-7636
    Monday to Saturday, 9am to 6pm
    They can source the engine and do the swap for you.
    Jun 2008
    efi fuel pump
    SPEEDLAB
    or
    SPEEDYFIX
    Thank you po sir. compatible kaya yun mga galing sa lancer? salamat po ule
  6. #6
    palitan mo nalang ng buo...ung efi na talaga.. direct bolt-on lang basta galing sa 91 galant din or 87-93 lancer or sa RVR..
    papalitan mo nalang siguro is ung addition ng electrical pump and the fuel tank.
    Jun 2008
    Quote Originally Posted by alwayz_yummy View Post
    ha? bakit pati fuel tank?
    Quote Originally Posted by Dann Pill View Post
    It's probably technically possible but using a Lancer engine would result in too much load on a small engine resulting in higher fuel consumption. Best to look for the 2.0L efi engine that this car came with.
4G63A Carb engine pwede ba maconvert sa EFI???
