Results 1 to 15 of 15
Threaded View
    hi tsikoteers ..
    our legendary 4jx1 strikes again!
    this time namamatay ang engine .. kahit tapakan ang gas pedal namamatay parin .. dahan dahan bumababa ang revolution kahit diinan ang tapak sa gas and namamatay ..
    we tried cleaning the 1 month old genuine fuel filter pero wala namang tubig na nakita ..
    nag try pa yung mechanic na ihipan yung fuel lines pero hindi naman barado ..
    the lines is clear pero the engine wont start again ..
    this happen last monday when dad ko may gamit ng trooper and nung nagpasundo na sila bigla nalang daw namatay ang trooper ..
    what could be the problem? well maintained ang unit .. mga 70k palang tinakbo and im using Royal Purple 5w-30 and also using genuine fuel and oil filters .. newly replaced lahat last june and sa speedyfix ako nagpapagawa ..
    the mechanic said na baka daw computer box pero hindi kami convinced ..
    hindi kaya loose wiring connection lang ng valve sa fuel lines from the ignition ?
    pag pinump manually yung fuel pump nagstastart ang unit pero namamatay din after a few seconds ..
    parang walang supply ng diesel going to the engine ..
    yung isang mechanic may minention na baka raw "magnetic valve" ang may sira ..
    then may isang mechanic naman from isuzu na ang sabi fuel injector daw ..
    GOD wag naman sana coz bumigay narin injector namin dati and we waited 6 long months for the parts and magkaiba ang symptoms sa ngayon ..
    hindi kaya fuel pump?
    or electrical problem lang?
    umaandar naman ang unit kapag pinump ang fuel pump manually ..
    may connection ba dito ang computer box?
    mga fellow tsikoteers i need your help ..
    ano kaya prob and whats the remedy?
2005 Isuzu trooper 4jx1 namamatay and wont start!
