Results 11 to 11 of 11
- May 2006
- 424
July 15th, 2006 08:33 PM #11Ang alam ko pag L3 FB palaging mausok. hehehe
Mausok siya when I gave a rev sa pedal. So far, tahimik ang engine pag nasa idle (but di yata ito magamit as basis, di ba?) .... Power steering still works... Sigurado timing belt at all the belts kailangan ng palitan...
How do you test for loose compression? Di ba overhaul na kailangan pag loose compression?
My base Q would be, in any 6 year old vehicle/unit, assuming di naman PALAGI mabigat ang karga, 200K mileage ang takbo, parang kasi ginawang Taxi/pampasada... Wouldn't the engine SUFFER a lot din?
200K divided by 6 years == 30K mileage in a YEAR.. Parang nakakatakot, di ba?
high idle RPM at engine start
