Where do I find a shop that specializes in engine support repairs? and how much is the usual charge? thanks. BTW, my car is a lancer 95 glxi, thanks in advance!
...if you can't find any, shops like cruven can fabricate one for you .-- though ang sabi sakin ng mekaniko, mas matigas siya, hence more vibration
Just buy a new support and have a mechanic put it in. You can DIY (Do it yourself) if you have the tools, but some supports are hard to reach.
Be sure that you buy a good brand. Some cheap replacement parts are made of very soft rubber, and will give out faster than the stock or original supports.
Cruven can fashion you engine supports out of solid rubber. There will be more vibration (sometimes... sometimes not really), but they'll last practically forever. Definitely costs less than original supports.
engine support fabrication is usually done when parts aren't available anymore. parts are still abundant for the lancer itlog, replacement or original.
if you're going for replacement, get the three-five (555) brand from a reputable auto supply. it's the best replacement engine support for the lancer.
you have four engine supports, two under the engine, one at the right and one at the lower left (all when facing your engine from the front of the hood). change all of them at the same time.
engine support replacement is a routine repair. all reputable shops can do it.
Maybe i'll just buy a replacement and have it installed. Thanks for all your help!![]()
I just had my engine supports replaced last Tuesday at Cruven Sucat.
My car is a Mitsu Galant SS 2.0 MT. It cost me around 5.5k (parts and labor).
Replaced all 4 engine supports (iba-iba yung price ng support & labor, pinakamahal yung sa back).
After the replacement wala na yung vibration and tahimik na makina ko...parang brand new... ;-) and nakatulong rin sa suspension ko sa harap, hindi na masyado ramdam mga lubak...
and mas masarap ng mag-drive...
yung Air-Con nman next kong papagawa (hay, gastos!).
5.5K? magastos nga pla, I hope it'll be much more cheaper for my car since lancer lang naman, thanks for the info bro!![]()
you can also canvass for JAC engine supports sa suki mong auto supply.
japan replacement yan ng oem engine supports for japanese cars.
goodluck bro.
jac is a good brand. figure, mga +/- 1k per pc yung replacement support pag magandang quality. a little more kung may fluid sa loob like the one for the accord.
Best "PreFab" Engine Supports in TOWN!!! M7 San Juan/M7 Banaue/M7 Pasig
Im proud cause the owners son is my friend ^_^
bring it over, malay mo makahanap. in case wala then just have it fabricated.
After changing my engine mounts on one of my Rangers, i feel the shaking again after a week. The shaking im referring to is when Im in 1st gear and going up an incline(bitin) or from a halt in a flat surface. do i need to re-tighten it?
