With this project, the carb is not going to be modified in any extent so it could be used normally.
Upon starting engine normal fuel line is used. When the exhaust temp reached the desired number, the fuel valve is closed and the vaporizer valve is opened.
the Vaporizer spray is electronically controlled and based on the car speed it will be increased/decreased.
The vaporizer box will be made of galvanized iron with air filter hole and gas exhaust hole going to the carb air intake.
