Results 1 to 6 of 6
- Nov 2010
- 2
February 5th, 2011 07:03 PM #1Mga gurus pls help.
i hav a 1997 corolla xl and from the time i got the car 10 yrs ago palakas ng palakas sa gas.
so i later decided na lpg nalang gawin but nw nagloloko na i have to tune it every once in 2 months. and the carb seems to be broken so am opting to have a efi installed.
carb itself new one would cost me arnd 15k.
how about efi anybody has an idea?
fyi. umaandar naman ngayn n ok pa makina. carb problem lang d ko na kc magamit with gas.
tnx
- Jan 2005
- 445
February 7th, 2011 10:40 PM #2You need a computer box and a lot of sensors, might cost you minimum of P60,000 and efi would fail if you use lpg.
Kaya lumakas yan eh malamang wear and tear na ng cylinders or valves.
Certified MB Addict
- Apr 2007
- 2,284
February 7th, 2011 10:45 PM #3Kung icoconvert mo rin lang yung 2E mo from carb to EFI, might as well just change the engine to an EFI unit like the 4E-FE.
- Nov 2010
- 2
February 9th, 2011 07:05 PM #4sir's
tnx! another question if i got a 4efe is it possible to just swap everything but retain the block andun kc ung engine no.
having paper problems w/ this car
tnx
February 9th, 2011 07:42 PM #5
The problem of increasing gas consumption sounds like you have worn out valve seals.
Given it's getting old and older, why not have the engine checked before doing anything else? It would be pointless to modify a broken engine because it will still be broken after you modify it.
Alternatively, you might be able to get a 4AFE with computer box for under P20K (without tranny) at the surplus shops.
February 9th, 2011 07:44 PM #6
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
