Results 1 to 10 of 10
    Good Day fellow tsikots ngayon lang ako nag OL. Patulong po, nag palit na ako ng bagong Spark Plug at Fuel Filter ng 2006 Toyota Innova Gas pero palyado sya habang stop ako (bumababa ang RPM ko at ang tunog nya yun jhug jhug jhug). Tapos habang umaandar ako, may delay lang sandali at mawawala ito kapag mabili na ang takbo ko. Ano kaya ang problema?
    Thannks in advance, I appreciate your tips/comments
    Quote Originally Posted by drich_enriquez View Post
    Pareho ba ng part number ang spark plugs na ipinalit mo bro? Most probably ito ang dahilan ng pagpalya...
    Fuel filter - Toyota part ba ito?
    Yun sa Spark Plug pareho po at sa Toyota ko binili yun Spark Plug. Yun Fuel Filter pang Innova pero ibang brand binili ko. (JS Asakashi Japan)
    May 2011
    Where are the pictures of the spark plug tips?
    We can be guessing your mystery and you might end up changing good parts.
    May 2019
    Did you check the new spark plug’s gap before putting them? Is the check engine light on? Was it running fine before changing the plugs?
    if your old plugs are still available, ibalik nyo and see if the problem disappears.
    if it disappears, "then you have your answer".
    yes, i know it's simplistic, but it is also costs next to nothing.
    May 2011
    At this time you probably threw the old plugs already or you can't trace which one came from which cylinder. When you check the newer plugs, mark each one from which cylinder it came from, take pictures and post them. Do not clean them before taking pictures. As an experienced technician, I mark the plugs for diagnosis and analysis.
    The used spark plugs are ones of the best engine performance or drivability diagnostic tool.
    [QUOTE=dr. d;3092931]if your old plugs are still available, ibalik nyo and see if the problem disappears.
    yes, i know it's simplistic, but it is also costs next to nothing.[/QUOTE}]
    Nagawa ko na na ok sya. Kaya lang after 3 days bumalik ulit.
    Ok I'll check it thanks sa tips mga sir.
    mina_nuka
    serkoserso
    Jun 2005
    Have the throttle body and MAF sensor cleaned.
    Ganyan ang symptoms ng maduming TB sa mga toyora vvti engines
    Sent from my MI MAX 2 using Tapatalk
2006 Toyota Innova Gas Engine "Palyado". Pls Help
