Results 1 to 11 of 11
    Feb 2005
    Kapatid, oks ang makina na yan for the Starlet. Fuel consumption is ok. AFAIK, mga 95-97HP yang engine na yan, which is enough to propel the Starlet. Parts wise, hinde ka (pa) gaano mahihirapan.
    Pa gusto mong gawing pocket rocket yang Starlet, palitan mo yung 13T-U ng either 18R-G or 2TG (both from Toyota).
    kung ang nakamatch diyan ay 5speed tranny...panalo....sabi nga e "kailangan pa bang imemorize yan!!!"
    anyway, what you should worry actually is the extent of rust ng oto...my KP was sariwa sa labas but the rust inside was damn too bad....inabot ako ng more than P20k sa body repair wala pa ang paint...mas mahal pa sa pagkakabili ko sa oto.
    yeah guys , i know you probably forgot but i recently supercharged my 13t-u in my KE70 corolla and it's runnin like a nasty wilderbeast!!!
    3/4/5 k engines are good if you would not load any air conditioning. If you do, there is much resistance when accelerating from 0 km per hr. A t series engine packs a lot of torque even if you install a dual air con.
    Apr 2008
    kung magpapalit ka ng makina sa starlet mo na mas mataas pa ang displacement sa original na makina mo, don't forget to upgrade your hydrovac brake master kasi kung ang gagamitin mo pa rin yung stock nyan sa oras na magpatakbo ka ng mabilis tapos magpepreno ka mapapansin mo na humina na ang preno mo.
    medyo may kalakasan ang mga naiisip mong makina lalo na yang 7K, 3T/13T at 4AGE.
13 T-U Engine Under Starlet 81's Hood???
